Question about RCA DRD485RG DirecTV DTV Receiver
Absolutly no signal on any transponders, all @ 0
Working perfectly, then lost signal.
physically checked dish mounting, check cable connections,
tried reset, unpluged receiver, removed card & reinserted
    Novelist:
  • 59 Answers
Hi johnbean,
It sounds as though you've tried a number of things already - I'm sorry to hear they haven't worked. Here's what it sounds like to me:
First, it's possible that the problem could be on DirecTV's side and not yours (if the signal they are transmitting was interrupted, then it wouldn't be relayed to your dish by any transponders). But since some time has evidently passed since you started having this problem, the odds of this being the case are slim (unless they mistakenly turned off your service - you might call and ask; it's been known to happen).
This can also happen due to weather - if there is substantial rain or cloud cover where you live, this can interrupt the reception of your dish. But if it's sunny, then you don't need me to tell you that the problem obviously lies elsewhere.
If you're seeing the transponder notifications on your TV (but you're not getting any signal), then the cables connecting the dish and receiver, and between the receiver and TV, are still working properly. Therefore, the problem has to be with the dish itself. Unfortunately, this is not something a customer can test on his/her own. I recommend calling DirecTV for technical support and, if that fails, you may have no choice but to schedule a repair visit. If the unit is under warranty, it may cost you little or nothing. It's always possible that the dish could be defective, and if that's the case, they should replace it at no cost (since you already pay for monthly service), so you might inquire about this possiblity.
I wish I could offer you better news, but this is a problem that only someone with the right testing equipment can accurately diagnose. Pleawe let me know if your situation changes, or if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 14, 2008
    Master:
  • 479 Answers
As u hve checked all possible things. i strongly feel the set top device is faulty .replace it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas you can try:
  • determine in the Setup/Menu if you can get "signal strength" reading;
  • remove the coaxial cable, with a voltmeter, pls check the voltage coming out of the jack at the rear of the receiver. You may need a pin to reach the center post. In most instances, the voltage would be AC but try either AC or DC;
  • could there have been a firmware update? Pls check with your provider;
  • if available, try a different receiver in order to determine if receiver problem or cable and/or LNB.
Incidentally, similar concerns have been attended to on this site here as posted in another response and here.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 734 Answers
This receiver has a low speed data port. so, try to update....... to Fast ------
1. Go to the menu and to reset.2. Enter reset recorder.
3. After it reboots, enter "0 2 4 6 8" to retrieve the current software (O18).
4. Screen should indicate "new software found" and updating.
5. Set up your satellites again via the menu settings
6. Tuner 1 and Tuner 2 have strong signals
Thanks
  • 75 Answers
Go into the menu and check the signal strength...if the signal is blinking..the receiver will need to be replaced....
    Genius:
  • 1,847 Answers
The disk positioning should be the issue,
the set top box could be faulty as you have already done the basic steps.
    Sergeant:
  • 306 Answers
I suppose the the "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to.
     If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem.
I have no signal,what can I check?
OK Joan,, I might need more info. not getting signal could be caused from several things.. one make sure the Dish Antenna is mounted correctly, (level, and true, [one degree off on earth is like 700 miles off at the Satellite.]) check you cables and make sure they is now wire touching the center core of the coax. if the coax has splitters, connections etc outside check for the corrosion inside the threads.
make sure the coax coming into the house is connected to the right place on back of the 222k. make sure u are on the right Video stream for the HDMI. are u getting any picture showing the Dish set up or is the screen all Blue.. if it is blue try to use the remote that came with ur TV (RCA, Vizio, Phillips,,,,etc) and look for the input, source , or Antenna button and push it to match your HDMI input..
Oct 28, 2014 | DISH Network Vip 222k Hdtv Satellite...
Humax Freesat was working fine then lost signal and now is not reognising postcode. We have unplugged/repluged, checked all cables (all OK) and tried to restart but as it is now not recognising postcode...
This can happen if the dish is slightly misaligned. I believe the postcode tables are read from a satellite which is about 0.3 degrees away from the Astra satellites. If your dish is slightly misaligned it may not be able to receive it correctly, also the following is the standard procedure which you've probably already been through, but I hope it helps:
1. Freesat Detection Fails / Invalid Postcode
  • Unplug the Foxsat-HDR from the mains and unplug the cable from your dish which is connected to the LNB IN
    connection.
  • Check that the "F-type" connector is firmly on the end of the cable.
  • Power on the and follow the Installation Wizard again.
2. If still not Detecting the signal or verifying postcode
  • Select NEXT through the Installation Wizard and then FINISH at the end.
  • Press the OK button to enter the SETUP menu and Select Manual Tune.
  • Select the following Transponder (11428 H 27500 A) from the list of Transponders.
  • Check that you are receiving stable levels for both Signal Strength & Signal Quality or >50%.
  • If you are not receiving sufficient Signal on this Transponder then you may require an installer to check your
    Dish Alignment, LNB, cabling, or connectors.
Nov 16, 2017 | Humax FOXAT HDR DTV Receiver
Receiver lost signal, cannot aquair
It sounds like the dish may be mis-pointed since it's not recognizing all the satellites. The next step for this would be to send a technician out to get everything fixed.
If you would like any assistance setting up a technician, just send me an email at thomas.faust@dish.com and I would be happy to help.
Tommy Faust
DISH Social Media Representative
Jul 01, 2012 | DISH Network DVR-625 DTV Receiver /...
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
Picture breaks down on some stations saying no signal or signal weak.
2 possible solutions, 1. If you have any type of dish network, go into the service part of the menu and check the signal strength usually a signal on any of the transponders less than 70 will cause this on some channels due to thier own signal. You can have either a tech come out,( sometimes for free, or you can adjust the dish very i reat very small increments so as not to diviate from the correct izmuth setting originally aimed at. to do this, you can do it yourself by selecting signal strentgh meters on the menu and raising the volume so you can hear the repeated blips while adjusting the dish. The sound your looking for is like the old Pong game on atari. The faster the blips, the stronger the signal. Slower blips mean your aligning the dish in the wrong direction.
2. Check your coax cables. If their old, they may not support the bandwidth being sent through it. Check at connections, ( All of Them) they wear with age. Is the cable itself at the connection protruding enough to enter the receiving female part. When you unscrew a coax at the connection, it should have about 1/8" to 1/4" copper cable past the connector and in clean, good, straight condition. make sure they are tight, and good luck
Dec 03, 2010 | Panasonic Televison & Video
It pause temporarily at times during regular tv programming. What can the problem be?
I'm not quite sure what you mean by "pause", but if you mean the picture freezes or pixellates and the sound cuts outs then it's caused by a bad signal - know as "Digital Cliff Edge" - see attached image.
If you are using an aerial, check all your cables are connected properly and that your aerial is securely mounted, pointing in the right direction and none of the elements have become detached - particularly the dipole where the co-axial cable attaches.
If you are using a dish, again check all your cables are connected properly and that your dish is securely mounted. If the bolts are loose and you can move the dish by hand, then it's possible that your dish has moved from the correct alignment. You will ideally need a signal meter to correct this although it can be done by trial and error.
You should also note that dishes are susceptible to signal-loss during bad weather, particularly strong wind, heavy rain and snow. If you are only losing picture in bad weather, there isn't much you can do apart from making sure the dish is rigidly fixed.
If your aerial/dish is OK, try replacing your fly-leads (the short section from the wall socket to the TV) and/or the cable from the aerial/dish to your TV.
Hope this helps.
BElectric
Nov 05, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my...
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Nov 04, 2009 | Philips DIRECTV H20 DTV Receiver
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
No dishnetwork signal
OK here we go .the most common problem with dish network and directv is that any cable connections you have that are on the outside of the house are a HUGE weak point in the system.what you want to do is go outside and locate the dish once you have start following the cables until you find any of these cable connections or splices.once you have located them get a 7/16 wrench and remove the cable ..What your are looking for is corrosion in the cable connection.it will look like rust.What happens is your dish system sends 13 and 18 volts down the line to switch channels.When any water gets in these connections it will start to short the connection BUT,you will still get TV for a long while eventually this small short will start to damage the cable connection and you will lose signal all together.make sure to check all of these OUTSIDE connections.Once you find one that is bad you can go to radioshack and buy a cable prep tool that STRIPS the coax"COAX STRIPPERS" to its correct lengths.simply cut off the old connector and replace it.There is a GREAT tutorial at satellitescoop.com that shows you how to do this the right way for under 10 dollars make sure to follow the directions on that site and you should be watching TV in no time.
Dec 29, 2007 | Televison & Video
Open Questions:
RCA DRD485RG DirecTV DTV Receiver Logo
272 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
