Question about Kenmore Elite 45986 Front Load Washer
How to INSTALL the shipping or transport bolts prior to moving my washer?
To avoid suspenison and structural damange to your washer, it was be properly set up for relocation. What is the procedure for installing the shipping or tranport bolts that came with the washer?
  • 67 Answers
Re: How to INSTALL the shipping or transport bolts prior...
There should be i think 3 holes in the back of the washer and u need i believe the orange shipping bolts and they screw into the back to hold the drum in place because if u move without the u have a very good chance of breaking the shocks which there are 4 and they are about 30 dollars each plus the price of labor of installing new ones and there not very easy to get to.
Posted on Mar 20, 2007
0 characters
3 Points
Install shipping bolts
This will not be necessary if the machine is transported on its back lay it down carefully on its back should not be a problem
Nov 06, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot ( The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
Transport Screw
The "transport or shipping" bolts are located at the rear panel of the washer. There are four of these bolts used to support the suspension system during the transport to prevent damage to the washer. These bolts are removed prior to the first use of the washer and caps are usually placed in the holes left by the bolts. When removing the bolts, remove the lower ones first then the upper ones. Keep the bolts and spanner, if there's any, for future use.
Mar 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Where do I get bolts to move my washer, do I really need them
the shipping bolts should always be in place when transporting the machine but i can also depend on how far you are traveling and the road can order them from a local parts store
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a LG WM0532HW. What are the drum bolt sizes thr.& length
Hello Jeff,
Unfortunately, these are specially made bolts that have threads only on the first section of the bolt, so they can secure the wash drum and not interfere with anything else. You also need the special sleeves for the bolts. I would not try to use standard bolts from a hardware store, as they could damage the wash drum if you overtightened them or they were too long. LG, and most washer manufacturers, don't publish the size, thread count and length of their transport (shipping) bolts, hence the reason they advise to keep them for future use.
So if you're only moving the washer down a set of stairs, you should be fine if you take it easy and either hand carry it with two (2) people, or use an appliance truck to move it down the stairs.
If, however, you're looking to move the washer any distance via truck, etc., you'll want the shipping transport bolts and sleeves to keep the drum and suspension system from getting damaged.
You're best bet is to get in touch with LG customer support and obtain a set of the transport bolts. You can reach them by callling them from 8AM to 8 PM toll free at 1-877 714-7486 and follow the prompts to reach customer support.
Here's a link to the owner's manual for your washer, just in case you've misplaced yours.
Hope you find this Very Helpful and best regards!
Dec 13, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Transporting bolts
Remove them PRIOR to operating your washer, or you may cause serious damage to the appliance. Those are used to keep the internal components and suspension immobilized during shipping.
Sep 03, 2009 | GE WCVH6260F Front Load Washer
Does a Maytag Neptune MAH6500WH have retaining bolts or pins that need to be installed before it can be moved?
If you are moving the washer for a long distance move, it is recommended that the shipping bolts be reinstalled to help prevent damage to the drum and suspension mechanism. This would be especially important if you're using a professional moving company, as they won't be able to move/load/unload it without problems.
If the move is relatively short and won't experience alot of aggressive movement, you can likely move the washer without chance of damage - provided you are careful and don't bounce the washer around.
Here's the info from the Maytag website, regarding moving front loading appliances:
If you are moving to a new home and plan to take your front-load washer and dryer pair with you, please call 800-688-9900, and speak to a fabric care expert. Our expert can recommend a Maytag-authorized servicer who will reinstall new shipping bolts to your washer.
New shipping bolts must be reinstalled to avoid internal suspension and structural damage to your washer during transport.
OK, so get your model number handy and give them a call, (you're missing some digits/alphas) you can get an online copy of your owner's manual that will show you the part numbers for the shipping bolts, if you've misplaced them, or give a call to the toll free number for Maytag, and they'll provide you with the part numbers needed so you can order them yourself and likely save some money versus having a service tech some out and do it for you/
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Hope you find this very helpful and best regards!
Aug 18, 2009 | Maytag Neptune Washer
URGENT~no clue how to reinstall transport bolts for moving washer
The long one go on the bottom and the short one go on top the hole for the shipping bolts are on the back might have a clear plastic cover over the holes on the back panel there is only one way to put them in start by hand tighten the bolts with nothing in the drum the holes should line up one you fill the catch and get hard to turn start using a wrench when it is done try shaking the inner tub it should not move all the shipping bolts do is keep the tub from slapping around inside the cabinet and breaking things Good luck
Apr 03, 2009 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
1,551 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
