Please, my pc leaves this message on start up" Could not open ACPIATK0100 kernel mode driver" how can i solve this?
  • Jake Teeh Dec 17, 2008
    Thank you so much for helping me with the link you game me to download the camera utility. It's working now. you are marvellous. Thanks also for this advice also. Byee for now.
  • 558 Answers
This is typical in the use of your Word writing application likely you cant use it.
Reinstalling word may solve this issue.
Posted on Dec 14, 2008
How to stop Windows 10 from automatically restarting after idle for around 5-15 minutes.
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Before we proceed with the troubleshooting steps, please answer the questions given below.
a)Do you remember making any changes prior to this issue?
b)Did you check if all the drivers are up to date?
Let us follow the methods given below.
Method 1: Run System maintenance troubleshooter.
Follow these steps:
a) Press Windows key + W on the keyboard
b) Type Troubleshooter then click on Settings under the Search field
c) In Settings click on Find and Fix Problems
d) Click on System and security
e) Click System maintenance follow the prompts from there.
Method 2: Try booting the computer in safe mode and perform a clean boot.
Step 1: Perform Safe Mode
Click the link and follow the steps "Windows Startup Settings (including safe mode)"
Check if you face the same issue in safe mode. If the issue doesn't persists in safe mode, the place the computer in clean boot and check.
Step 2: Perform Clean Boot.
To help troubleshoot error messages and other issues, you can start Windows 8 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
Important: Reset the computer to start as usual.
Note: After you have finished troubleshooting, follow these steps to boot to normal startup.
a) Press the 'Windows + R' key on the keyboard.
b) In the 'Run' windows type 'MSCONFIG' and click 'Ok'.
c) On the 'General' tab, click the 'Normal Startup' option, and then click 'OK'.
d) When you are prompted to restart the computer, click 'Restart'.
If the issue persists, I would suggest you to perform a system restore and check if it helps.
Method 3: Perform a system restore.
Refer to the link given below and follow the instructions for system restore.
How to restore, refresh, or reset your PC
Also refer to the article given below.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
hope this helps
Jan 13, 2016 | Computers & Internet
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
This message appeared " driver_irql_not_less_or_equal" TECHNICAL
Hello !
This system-halt message occurs when a process (in kernel-mode and not user mode) or driver tried to access a memory address to which it did not have permission. The most common cause is an incorrect or corrupted pointer that references an incorrect address in the memory.
When this occurs in a user-mode application, it generates an access violation. When it occurs in kernel mode, it generates a STOP 0x0000000A message. If you encounter this error while upgrading to a newer version of Windows, it might be caused by a device driver, a system service, a virus scanner, or a backup tool that is incompatible with the new version.
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. Choose the "Last Known Good Configuration" option. This option is most effective when only one driver or service is added at a time.
Usually, from my experience this rarely happens, but it is a buggy DRIVER installed by you.
Get back with more details please if it still happens. (Tip : Try to re-install all drivers using the manufacturer's website).
Aug 02, 2011 | Microsoft Windows XP Professional
Error message "carnt open ACPIATK0100
I would download and run the registry utility from
It is freeware and works then run CHKDSK/F.
Hope that helps.
Mar 07, 2011 | Toshiba Satellite Pro L300 Notebook
Error message can' t open acpi atk0100 kernel mode driver on notebook toshiba satelit l40
maybe it's installer format cant be read by your notebook. try to look other driver installer format.
May 02, 2010 | Toshiba Satellite Pro L300 Notebook
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Does it boot in safe mode?
To check, please follow the steps below:
1. Power on your computer
2. Immediately begin tapping F8
3. Keep doing so until you reach the Boot Options menu
4. Select Safe Mode
5. Press Enter
This will load windows using a minimal amount of drivers.
Jun 23, 2008 | Toshiba Tecra TE2300 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
