I have to fill the system ,because I was some time away. I Filled the water tank. Then I pressed steam, It is working some time, no steam comes out then it shows again fill system
service required is written on the display. Service is done, but the writing still stays, although...
(More)
service required is written on the display. Service is done, but the writing still stays, although the machine works perfectly. Is there any way to solve this?
S8 machine shuts off immediately after rinse cycle. Is there a reset button or procedure? Another...
(More)
S8 machine shuts off immediately after rinse cycle. Is there a reset button or procedure? Another trip to the refurb factory? Jack
My S8 was off for about 2 years! Now I can't get the water to go through the coffee mode. I do get...
(More)
My S8 was off for about 2 years! Now I can't get the water to go through the coffee mode. I do get the tea potion and limited steam potion. Any ideas?
I have an Jura Impressa S8 and the coffee it produces has always had a slightly oily flavor (a...
(More)
I have an Jura Impressa S8 and the coffee it produces has always had a slightly oily flavor (a machine oil flavor). I have washed the machine several times by putting the tablet into the coffee grinder and that has not changed the result. I have also tried the unit with and without the filter, and different types of water (plain tap, distilled, externally filtered, etc). The oily taste is present regardless. I have also tried several different coffees from different sources (Peet's, Starbucks, other specialist producers brands, etc). The oily taste persists. Any suggestions?
