Question about Toshiba Satellite A75-S226 Notebook
I LIKE TO KNOW HOW MUCH RAM I CAN PUT ON A TOSHIBA A-75 LAPTOP AND WHERE IS THE RAM ON THE LAPTOP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Hi
    The Maximum Supported Ram that you can Install in the Machine is 1536MB (or 1 x 1GB Stick & 1 x 1 512MB Sticks of Ram, if you have 2 Ram Slots that is).
    On the bottom of the laptop you should see 4-5 Screws that hold in place a Shaped Plastic Panel (Not the whole of the casing on the bottom, just a section.) You take that off to access the Ram Area.
Posted on Dec 14, 2008
My toshiba l675d-s7013 laptop screen won't come on?
hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Dec 02, 2012 | Toshiba Satellite Computers & Internet
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
I think i need to add ram to my toshiba satellite laptop and i do not know how to figure out what to buy.
if u think to add ram on your laptop then frist cahck your laptop is there amty slote on ram place
u can chack back site of your laptop
cahck what ram your laptop is supporting after that same type of ram u can add.
Apr 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do i replace ram in a toshiba 2450
Unclip top trim the one with the on button ,undo 3 screws lift up the keyboard and put in your memory in the slot under the plastic reassemble in reverse order
Cheers
Sky
Feb 20, 2010 | Toshiba Satellite 2450-401 Notebook
How much memory can i put in this laptop?
According to the detailed technical specs of this laptop model, you can add up to 4 GB of RAM.
Nov 28, 2009 | Toshiba Tecra A8-S8514 Notebook
My toshiba l 305 will not turn on.. in fact, the led light that indicates that it is charging will not come on either.. I read a blog of someone with the same problem... they removed the ram and batter......
you will find the ram if you put your laptop upside down. you will see several screws. the ram case it's bigger than the other and it usually in a central positiion.
handle with care. if it doesn't work send it to warranty if you still have some. if it's not from the ram it could be a serious hardware problem.
hope this helps.
Oct 11, 2009 | Toshiba Satellite L305-S5877 Notebook
Computer will not turn on just a loud tone
Turn off your laptop First.Then Relies your Battery of your Laptop.open the back cover And put off the RAM of your laptop CAREFULLY,CLEAN IT WITH SOFT CLOTH.again put the RAM in the RAM slot , Cover the case .Again put on the battery on the Battery case. Now Boot the laptop
Sep 11, 2009 | Toshiba Satelite 5205-S505 Notebook
I have toshiba laptop Model satellite 205 s406,display not coming up,what is the reason,how to fix it
FIRST OF ALL YOU CAN CHECK THE RAM
YOU CAN OPEN YOUR LAPTOP AND FIND THE RAM
IF YOU FIND RAM SLOAT
THEN CLEAN THE RAM
AND PUT AGAIN
Aug 26, 2009 | Toshiba Computers & Internet
I need to know how much RAM I can add to my Toshiba Satellite 130/135.
2GB maximum on this series.
You can therefor put up to 1GB per memory slot.
The RAM you are needing is PC3200 SODIMM 1GB and if you want to max out the laptop you will need 2 of them
Chris
Apr 30, 2009 | Toshiba Satellite A135-S4527 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
Toshiba Satellite A75-S226 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
