Question about Sony CDX-C5850
No display i just finished installing this cd player in my car and when i turn it on, it make the noise when it firsdt starts and takes a cd....but nothing shows up on the screen and nothing comes out of the speakers. checked all the wires and they are connected properly, please help!
  • 156 Answers
It sounds like the unit is not receiving power on the red (switched power) input. Check your vehicle's "radio" fuse.
Posted on Mar 15, 2007
SOURCE:
Honda 12 odyssey cd player says bad disc eject
The symptoms suggest a CD is jammed inside. You will have to remove the player and open it up to find the problem and correct it.
Aug 14, 2016 | Audio Players & Recorders
Peugeot 406 cd player
Not old age, but heat. something behind the dash is creating heat, which is why things go dark over time and why it works aftt
Nov 16, 2017 | Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
How do I set the clock on my Pioneer DEH-P6200 cd receiver?
With the vehicle on, turn OFF the radio. Next, Press the Volume and hold the VOLUME knob. You should see LANGUAGE on the display. Scroll the VOLUME knob until you see CLOCK SET. Pres the VOLUME knob and the HOUR will start flashing. Scroll the VOLUME knob to set the hour then Press it to set the Minutes. When you're finished. Turn off the radio, then turn it back on. When the radio is in use, the Radio Station will scroll on the display, then the Artist information, then after a few seconds (20-30), the Clock will display.
Jan 14, 2011 | Pioneer DEH-P6200 CD Player
CD player Error 3
dear,
I have different experiance with the C.Dplayer ( error 3 ) , there is no need to remove it nor send it to the dealer ,all you have to do when you have `` Error 3 `` is to reset the C.D player , by recycling the power supply ,this can be done by disconnecting the main car battery power supply , you must also keep the battery disconnected for at least one hour . then connect the cables to the batteries ,when you start the C.D player you will hear some clicking sound ,and watch the numbers of the C.D`s in the display you will find all what is inside has been detected by the display .
and your C.D player is back to normal..
i discovered ths by chance , when I had this error in the past ,coincidently I had to replace the battery and after installing the new batteries ,i was suprised to see the player back to normal condition by its self.
Jun 02, 2009 | 2002 Lexus ES 300
Car wont start
charge the battery the full way...
may take a while
if that aint the problem then u need a new starter
May 19, 2009 | 2000 Plymouth Breeze
Need to set time on DEH1700 pioneer car cd player
Hi!
Turn the cd changer off and then press the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is set as required.
Do revert for any clarification. Thanks for using Fixya and do rate the solution if found helpful.
Thanks
Rylee
Apr 03, 2009 | Pioneer Car Audio & Video
I have a pioneer cdj 500 cd deck. Havent used it for a while , put cd in, makes a quiet whirring noise as if its about to start turning and then displays error 192. Cd door wont open, help please
You could try to spray some oil into the spindlemotor, sometimes(very rare) they tend to stick a bit and will not turn properly or keep the right speed.
Mar 14, 2009 | Pioneer CDJ-500II CD Player
How do i put code into a clio cd player????
cd player uses the display above the radio on the later model,either take it to reanult garage or put a belson in like mine whic plays USB/SD card/ CD/radio ,it was about 90€ and trust me it brilliant no more cds in car ,just one sd chip 2 gb all my favourite tunez on one device
Dec 27, 2008 | 2000 Renault 181
Cd player won't open
Try disconnecting the car battery for a few minutes, the unit may reset when you re-connect the battery. Worth a try.
Nov 20, 2008 | Alpine CDA-9851 CD Player
Sony CDX-C5850 Logo
73 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
