Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Hitachi 60V710 shuts off after 2 min
My Hitachi turns on for approx 2 min. it then shuts itself off, and then back on automatically only to shut off again after 2 min. the lamp was just replaced about a month ago. I'm assuming its a power supply issue.
  • cjmatte Dec 26, 2008
    thanks yeah i was told about over temp i pulled back off and cleaned it out ill check the temp sensor see what it looks like
    Problem Solver:
  • 15 Answers
Not an expert, but; 2 minutes is roughly the time it takes for something to go over temp.
So id be looking for an unplugged fan connector or similar issue. Its an odd problem where I suspect the bulb or sensor for the unit is reaching an over temperature situation as its unusual to start perform as expected then shut down. A sensor may have been damaged for one the improper bulb has been used. The tolerances for these devices are very fine, they normally shut down to prevent further damage like a baked lcd matrix etc.
If you are game to pull it apart or even to check it, then check for fan start at the time when it powers off, if it doesnt then thats a reasonble logical step for it powering off. So remove cover and check for fan being plugged in. Next step look around the bulb area for a small resistor shaped item that could be the temp sensor bent outta shape. Best of luck. :o)
Posted on Dec 26, 2008
Hitachi tv 60v710 turns off and on by its self every minute what it can be?
This problems it is related to the tv projection lamp.The tv projection lamp is inside the tv now.Been in the tv like a 1 1/2 or 2 years already?Tv is on and used it like 4 or 5 hours daily?Yes,than the tv projection lamp must be replaced should solved this problems.If the tv projection lamp already been replaced,than this problems are caused by the board that call the Ballast board.This Ballast board only job are to ignite the tv projection lamp only.
Jul 13, 2011 | Hitachi 60V710 60" Rear Projection HDTV
It turns on, runs for approx 20 mins then shuts off. when you turn it back on it shuts off in approx 12 min and so on and so on. is this a bad power supply?
possibly, it sounds like there is a capacitor in the power supply not holding charge anymore. Or it is loosing hold of the charge once it gets warm.
Mar 08, 2011 | Insignia 37" LCD Flat-Panel HDTV
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
My Hitachi t.v. goes off and back on at random it will not stay on for more than 3 mins without turning off then back on. What should I do??
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Hitachi 60V710 60" Rear Projection HDTV
I have a 60 in hitachi ultravision projection tv. lamo light blinking so I replaced the bulb and it still blinks,,
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!
Nov 23, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Lost the lamp cover is there a replacemnet
short your lamp door switch.. it may cause cooling issues but it will work. put on a table take the back off look in the area that the lamp door is there will be a switch.. trip it and tape it closed.. then turn it on if the lamp turns on you've got the right one..
Mar 12, 2009 | Hitachi 60V710 60" Rear Projection HDTV
I have an RCA SDTV Model: 24V414T The TV shuts off by itself after 1-2 min. and turns on by itself in the next 1-2 min and the process goes on. Can anybody help with this problem. Thanks
i have an rca tv shuts off by itself lite only the standby power after 2-5 minutes you can turned it on and will off automiticaly pls. help me with my tv model 24v414t.
Sep 21, 2008 | Televison & Video
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
145 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
