Question about Sewing Machines
Bernette sewing machine making a mess of thread on back of fabric
I have a Bernette 66 sewing machine that I'm still becoming familiar with. Whenever I start sewing, the bobbin seems to catch and sputter a bit, leaving a mess of thread on the back of the fabric. I'm certain I have the bobbin threaded properly-- I'm following the manual and there is tension in the bobbin. If I start sewing slowly, even just turning the handwheel, I don't have this problem. Any ideas would be much appreciated!
  • emmakiele Jan 02, 2009
    I'm having this exact same problem with my bernette 66.
  • angela_richb
    angela_richb Apr 20, 2013
    I am having a problem with my 66 in that I cannot seem to get the tension correct on a straight stitch. Doesnt matter what I set the tension, stitch width and length It either shows the bottom stitch on the top and the bottom stitch loops under the fabric . What settings do you ladies use for straight stitch?
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
Posted on Dec 14, 2008
Where do i foun the scarf and needle bar on bernette deco 600
The scarf is on the needle itself. It is an indentation on the back of the needle above the needle eye where the thread can sit as the needle penetrates the fabric. As the needle penetrates the fabric, the thread sinks into the indentation thereby resisting fraying or pulling on the thread.
The needle attaches to the bottom of the needle bar. The needle bar is the mechanism that moves up and down to drive the needle through the fabric.
All About Needles
Bernette deco 600 diagram Google Search
Mar 03, 2016 | Bernina Bernette Deco 600
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
How to sew stretch Bernette 66
is the needle turned the right way in the needle holder?
is the needle new or used, if you've used it before it could be
damaged at the point.
try another stretch needle, or a ball point, or titanium needle
Oct 19, 2012 | Bernina Sewing Machines
How to use elastic thread in a Bernette 66
Did you change the needle to one designed for elastic thread?
Aug 21, 2012 | Bernina Sewing Machines
My bernette 65 is bunching underneath. How do I resolve that?
Grasp the threads and hold them down when you start your seam. If it still happens make sure your thread is seated into your upper tension mechanisms. If that still isn't solving your problem... CLEAN between the tension discs with some sturdy fabric folded in half. (wax build up from threads can cause issues)
Good luck
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Under thread tension loose on fabric on a bernette 66
Take it to a qualified technician. Otherwise, you might try increasing the tension.
May 25, 2011 | Sewing Machines
The machine is threaded correctly but it is not stitching on the fabric,it was stitching but leaving spaces with no stitching ,so after re threading the machine and fiddling with the tension it now does...
First I would replace the needle. Next, completely rethread the machine, making sure the thread is passing through the take-up lever. Next, remove the bobbin and reinsert it. This is a good time to also give the machine a quick cleaning, in case lint or thread is building up anywhere. Then try sewing again on scrap fabric and adjust your tension.
I hope this helps!
Apr 01, 2011 | Bernina Bernette 75
Sewing Machines Logo
357 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
