Question about Samsung SV5000W VHS VCR
Faintly blinking power light
I have a Samsung SV-5000W SQPB VCR with power problems. When I plug it in, all is see is a faintly regularly pulsing power light. Any ideas? Thanks much.
  • cidaa Jan 19, 2009
    I have the exact problem of no unit response other than a faint blinking red light on the power button. As of yet I have no solution, or reason.
I've had this happen to me twice in 9 years. One or more electrolytic capacitors in the power supply have failed. Replace 5 capacitors C31-C35.
Posted on Feb 21, 2009
    Novelist:
    Champion:
  • 254 Answers
This may indicate power supply problems, or perhaps an overload condition, causing the power supply to go into overload protection. If you have a voltmeter, schematic (helpful but not 100% necessary), you could check voltages. You should see at +5 volts, +12 volts, and one or two others. A frequent power supply problem is one or more electrolytic capacitors go wacky, and cause the voltages to be way off, and a non-operational unit. If this is one of the newer low cost rigs, then taking it to a service center isn't cost effective. Toss it and purchase a new one.
Posted on Mar 16, 2007
SOURCE:
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
NTSC connection with satellite
interchange the wires probably they could be broken when the movement occured.good luck
Jun 16, 2007 | Samsung SV5000W VHS VCR
Samsung SV-DVD545 dvd / vcr combi unit cuts off after switch on
i would guess your vcr is not powered off completely preventing the dvd from playing
May 15, 2012 | Televison & Video
Samsung VCR SV-5000W Tracking Problem Symptom: I've used Maxell VCR Head Cleaner VP-100. Still having small white streaks across screen. I can apply small amount of pressure to bottom or top of VCR deck...
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Nov 26, 2010 | Samsung SV5000W VHS VCR
Blinking white sparks during playback. My unit has this problem during playback, and I discovered that the SV-5000W has the same problem too ( see http://www.fixya.com/support/t151239-major_dropout ). At...
I looked at the link provided and there was no cure mentioned. From my experience with VCRs in general, I would suspect a flaw in the video pre-amp circuit used for playback. This could be distortion. Without seeing the actual unit and examining the signals on an oscilloscope, I can't be sure where the problem exists. It should be fixable however. Something as simple as a bad filter cap at the heads could cause this as well. The signal levels at the heads are extremely low. This unit requires test equipment that the homeowner is nit likely to posess. I would take this to a service shop.
Dan
Oct 11, 2010 | Samsung SV7000W VHS VCR
Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Jan 04, 2009 | Samsung SV5000W VHS VCR
VCR Samsung SV-5000W
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Dec 28, 2006 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
493 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
