What position does the small lever on the right side of the T87 Honeywell Round T-stat need to be in to be OFF ?
    Problem Solver:
  • 12 Answers
The switch on the right side of the T87 is for the fan. Down is the auto position which will cause the fan to run only when needed. Up is the always-on position, used to circulate the air constantly. If you want to shut down all heating cooling associated with this thermostat you need to look at the switch on the left side of the stat. To the right is heating, center is OFF, and left is ac.
Posted on Dec 16, 2008
How to change the battery inthe honeywell thermostat 6000
If there is not a small door that opens on the top side or on the right side then you'd need to pull on all 4 corners of the body of the t-stat, straight out and not at an angle. The batts will be on the back of the body.
Sep 19, 2017 | Honeywell Heating & Cooling
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
IVE GOT A HONEYWELL T87A 3 WIRE THERMOSTAT MOUNTED ON THE WALL AND WHEN I WANT TO TURN ON MY HOT WATER BOILER I HAVE TO LOWER THE T-STAT SETTING INSTEAD OF INCREASING IT TO GET THE HEATING SYSTEM TO TURN...
I would switch to a two wire heating only stat It sounds to me like they have the boiler wired into cooling side. Do you also have to set switch on your t-stat to cooling or leave it on heating. Just curious. I would still go with two wire stat. Thanks.
Nov 11, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
We have a round thermostat made by Honeywell. I
The thermostat that you have is position sensitive. By that I mean that you need to have it in the right position for it to work correctly.
When you have the ring off of the thermostat loosen the two little screws and pull the thermostat away from the subbase. On the subbase you will see a line that needs to be level. If it is not level then the mercury bulb will not be in the right position to start and stop the furnace. Level the subbase and reassemble the thermostat and your furnace should start to work properly. If not then the thermostat is probbaly bad.
When they go bad it is often becasue ot the little arm that you refeered too. That is a small heater than actually fakes the thermosat into thionking that it is hotter in the room then it really is. This makes the furnaces shut down a bit early to combat overshoot. Adjusting that will determine how much time before the furnace hits the shutdown temperature that it will actually shutdown... got that?? In others ward it is probably a good idea not tp mess with that unless you know what you are doing. However the heater can burn out and create problems.
So, check that the thermostat is level and if not get a new t-stat...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 11, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
HONEYWELL T87N 1000 ROUND THERMOSTAT
the power for that stat comes from the furnace - if you have no display on the stat you have a furnace problem
Sep 28, 2009 | Heating & Cooling
I've replaced my very old (mercury) Honeywell thermostat with a new one (round, Model: YCT87K1011), but I can't get it to control the temperature. If I connect the two wires one way, the furnace comes on...
Hey John, man that ole T87 has been around for a hundred years and I have installed many of them, but I cant remember the letters on the wiring. Seems to me that it is R-W-Y, any way you will use the R and W. I have a t87 at home still in the box and I could wait till I got home to help you but Im sure its the R and W terminal. Dont forget to set the heat anticipator. Set it the same as the current value of your gas or oil valve.
Nov 06, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
