Question about Mitsubishi VS-60603 60" Rear Projection Television
Mitsubishi vs50707 won't turn on
The tv will not turn on at ll and when we did the code test we got a code 24. is this a problem we can fix at home? If so , how? Or do we need a repair service?
    Genius:
  • 2,920 Answers
You need a repair man to come out
Posted on Dec 14, 2008
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Mitsubishi VS50707 - picture went out while TV was on. Sound still works. if i turn it off for awhile then back on, all three color tubes come on and flicker together for awhile before going out again....
The most common failure is the convergence IC's for what you are describing. They are large black flat-pack items mounted on aluminum, finned heatsinks. They will have numbers on them like STK392-110 or STK392-120. Yours may be different but most start with STK392-___. There may be some resistors that overheated and failed,... they are usually mounted near the IC's. They will be darkened towards the middle area. Google "Mitsubishi convergence repair kit" and you'll find suppliers who will sell you what you need , quite often with complete instructions. Here's the first one I found: http://www.tvrepairkits.com/xcart/home.php?cat=2638 This link is for your model number.
Aug 24, 2010 | Mitsubishi VS-50707 50" Rear Projection...
It won't turn on
on off sensor/switch bad, pretty soon it probably won't come on at all
Feb 26, 2010 | Mitsubishi VS-50707 50" Rear Projection...
I HAVE A MITSU VS50707 PROJECTION. THE PICTURE BOWES TO THE CENTER OF THE SCREEN AND PICTURE HAS THREE DIFFERENT COLOR HALLOWS. IS THIS A REPAIR THAT CAN BE DONE AT HOME? WHERE CAN I PURCHASE THE PARTS?
This is not a diy repair, unless you have a service manual, can follow a schematic or have circuit repair skills. The main cause is bad convergence ICs (large black ICs mounted to large heatsinks). The ICs go bad and usually take out micro fuses/fusible resistors when they short out. Another problem is they can take out the voltage regulators that feed the ICs. If you don't know where the fuses or the regulators are ( or how to test them) you can cause more damage then good, and turn a inexpensive repair into a very expensive one.
Aug 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Want to know if the VS50707 is an HD TV.
This unit is a analog television.
Jun 23, 2009 | Televison & Video
VS-50607 Mitsubishi code 24...replaced caps now code 22
Well, I don't know about your original problem but I can guarantee that 95% of the time when a Mits projection set gives a 2-2 code it's because the convergence output IC's are drawing too much current. Replacing the convergence output IC's usually fixes the problem.
Jun 05, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
Good Day, gntjige73 & muse923;
Let make this short and sweet, code 24 means you have a vertical problem. Four common things can cause this:
1. Bad connections on the convergence IC's,
2. Bad cap's in b + to vertical circuit,
3. Bad connections/or failing vertical output IC,
4. Or fluid on the PC board, leaking from the crt's.
The companies you called DO NOT call them back, but call a factory authorized service dealer, they will help you, but always remember to get a written estimate before you proceed with the repair. Good Luck, big IRISH>
Jun 26, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS50707
convergence ICs stk392-110 you will need 2 of them.
Mar 07, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Televison & Video Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
