Wiering diagrame for pioneer rs-60 reverberation amplifier
Could someone please tell me how to conect a rs-60 reverb amp with an equalizer, as i have lost the manual that came with it, many thanks.
  • 1894 Answers
SOURCE: VSX-D608 amplifier (Pioneer)
there is a manual for your audio/videp multichannel reciever..
http://www.google.co.in/url?sa=t&ct=res&cd=1&url=http%3A%2F%2Fmanuals.schematheek.com%2Fsheet%2FPioneer%2FVSX-21.pdf&ei=GtpxR8LIO4_I6gOO3bhG&usg=AFQjCNG77hxZYmnYw0HH7X5Q_DLbg_HU9g&sig2=pgaHRzbHHuKU2ZQW0UBO4w
Posted on Dec 26, 2007
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
XSdB
  • 80 Answers
SOURCE: difference between audio amplifier & OPAMP
An audio amplifier is a general term that applies to any amplifier specifically designed to cover the audio spectrum, and usually referres to power amplifiers (of any power from micro headphone amps (like the headphone audio amplifier circuit in an ipod) . to power amps like the ones used at rock concerts that are several thousand watts).
An OP-AMP is an Operational Amplifier, which refers to a type of amplifier circuit. Op-Amps can amplify audio, but are not restricted to it. They are used in many things from audio circuitry to signal conditioning, and sensing from all kinds of equipment from seismometers, to light sensors, temp sensors, insturmentation amps, lab amps... RF amps etc...
There are many many different types of op-amps that are designed for many different applications. Mostly the parameters are frequency response, gain, and input/output impedance.
Op-amps usually come in an IC package of some sort. The most common are 8 pin DIP package types.
Op-amps do NOT handle power. (although there are some hybrid power op-amps available, they are specialty devices) The term op-amp refers to the ability of the amplifier to be manipulated mathematically by external values. (i.e. resistors set up to add, subtract, or multiply the value of the input signal) Hence the term OPERATIONAL amp, because it is performing mathematical operations on the signal. (They were first used in analog computers, allowing the voltages to be added, subtracted, and such, and displaying the resultt by directly reading the voltage value).
They handle only small signals, and require being followed by a POWER amp to do anything useful, such as drive a spleaker, or a relay, or a transducer.
For your question, most all audio amps consist of stages.
There is an input/pre-amp stage (this is usually where the eqalization, signal processing, and bass/trebel tone controls are implelented) and a power amp (output) stage that takes the signal fromthe pre-amp and raises the voltage and current to a sufficient level to drive speaker.
The input/pre-amp stage is most usually composed of a series of op-amps. Op amps also are responsible for the bass/trebel control, and the EQ.
There will most usually always be several Op-Amps in every Audio Amp.
Posted on Jun 12, 2009
  • 12 Answers
SOURCE: I have a Pioneer GM H22 amp. Powers up nice, fan
On Pioneer, Green wires are left spkrs, Grey is right spkrs solid is positive black stripe is neg.
Posted on Jul 07, 2009
  • 5603 Answers
SOURCE: How to remove amp from cabinet? reverb doesn't work.
SOMETIMES the handle screws must be removed as well.
I have taken a lot of these out and the key is to figure out which direction it comes out... MOST are out the back and sometimes a board across the back has to be taken off with four screws to clear a transformer.
FIGHTING getting the thing out when it catches on the Tolex covering is the USUAL problem. Takes patience and sometimes a blade to hold the Tolex back.
USUALLY the speaker baffle stays in place.
Posted on Nov 12, 2009
I got this old Reverb Amp from cleaning out a house for a real estate agent. I was wondering its worth & how to go about getting it to someone who would like to have it. Thank You Its a Pioneer SR-202...
It's an old 'spring-type' reverb.
http://en.wikipedia.org/wiki/Reverberation#Spring_reverberators
I have one from the mid-70's, long unused. Digital reverb is more predictable and not susceptible to rom vibrations or jarring. There are those who would still want one.
You might put it out on eBay. They don't get much for them.
This auction expires in 2 days. The bidding is $20.50 right now. You might watch it to see what the unit eventually goes for.
http://cgi.ebay.com/Vintage-Pioneer-Reverb-Unit-SR-202w-/260777273468?pt=Vintage_Electronics_R2&hash=item3cb789687c
May 05, 2011 | Audio Players & Recorders
Kicker Amplifier v. Pioneer Head Unit
GET RED POS+ LONG WIRE 2 BATTERY 2 WERE UR AMP IS GANA GO CONECT IT TO THE AMP POS+ (2)GET NEG- WIRE CONECT 2 WERE THE NEG- IS ON THE AMP THEN THE OTHER END OF SAME NEG- WIRE FIND PLACE NEXT 2 AMP WERE U COULD SCREW NEG- TO CAR METL CLOSE 2 AMP (3)GET LONG REMOTE ANT. WIRE CONECT IT TO WERE THE REMOTE ANT CONECTION IS ON AMP THEN SEND IT TO UR PIONEER IS AND FIND REMOTE ANT . ON UR PIONEER HEAD AND CONECT IT SO IT SHOULD BE CONECTED TO UR AMP LAST PART GET THE LONG RC PLUUGS AND CONECT TO UR AMP THEN RUN THEM TO UR PIONEER HEAD WERE THE RC PLLUGS INPUT IS THEN IT SHUD BE DONE!!!
Mar 13, 2010 | Kicker KX500.2 Car Audio Amplifier
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
I was hocking up a other amp to my first one and to wiers toched and the red ligt came on and it makes no noise
possible not compatable with each other, wrong amount amp, too much power that cause it to disable amp (protection)
Apr 17, 2009 | Pioneer GM-5200T Car Audio Amplifier
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
Jun 15, 2008 | Audio Players & Recorders
Sanaui
This is a device which gives the illusion of more spacious sound by adding reverberation (echo) to the audio signal. This particular unit uses a mechanical analog delay mechanism employing a steel spring! Analog spring reverb units enjoyed some popularity in the late 60's and early 70's, with the Sansui and Pioneer units being the most common..
Feb 12, 2008 | Audio Players & Recorders
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
77 people viewed this question
 Grubhead
Grubhead
