Question about HP PSC 1315 All-In-One InkJet Printer
My printed and copied pictures have horozontal lines
I have really enjoyed my all in one printer. Recently I have horozontal lines running throughout pictures, both printed and copied. Replaced both ink cartridges, no help. Cleaned the new cartridges.. no change..printed the test a couple of times... Hepl please
  • Anonymous Dec 08, 2007
    I have a Lexmark X 83 como printer/ scanner/ copier.It's a little over 5 years old. For the last several months my color printouts have horizontal lines across them. I just inserted new cartridges, thinking it would take care of this problem, but it didn't. The lines are still there. Thanks for any help. dottyc28@aol.com
  • Anonymous Nov 17, 2008
    I have lines gowing through my printed and copied pictures. I've changed cartiges, and did a cleaning.
I work on printers daily and if I can make suggestion. The printhead (ink cartridges) are cleaned or wiped off before printing. Normally on the left of most printer at a cleaning station. You dont say what model you do have. but the rubber wipers accumalate the ink that the clean off the printhead and when they get too dirty thery generally dont clean the printhead as well as they should so they smear ink across the printouts. A wet paper towel to clean the rubber wipers, let it dry a bit then turn it back on and try it again. Good Luck!
Posted on Mar 15, 2007
    Novelist:
    Champion:
  • 202 Answers
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
SOURCE:
Lines on printout of pictures
Here's some thoughts that may or may not help you. =)
You could double check the Print quality and make sure it's at the highest. If the printer head is removable, you could take it out and clean any build up gunk on there. Sometimes it build up around the edges of the printer head.
If it's an old printer it may just need a new printer head. But they are not really worth replacing since they cost as much as a new printer. Not much else you can do other than have the printer self clean itself.
Dec 05, 2013 | Epson RX620 All-In-One InkJet Photo...
C5800 printing vertical lines through pictures
The thin lines are caused by a worn out drum. Remove each drum in turn and look at the surface. It maybe hard to see the scratches and if so then send solid blocks of the primary colours one at a time and that will prove which drum is at fault.
Oct 28, 2017 | OKI C5800Ldn Led Printer
Horozontal lines across picture
hai there...go to control panel,click prnter and fax.now choose your model printer,right click the model and go to properties...and then click maintenance...you will see a clean button and deep cleaning button...just click the deep cleaning and your printer will clean the cartridges automatic...
Feb 25, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Blue horozontal lines running through picyure prints
Try taking out your two ink cartriges, put back in and on your computer it should come up with an option to align (follow the directions). If does not work, then injectors/lazers might be out of line them selves. At that point call the company of the printer and they can help you more.
Apr 30, 2009 | Computers & Internet
Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Mar 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon i-550 printing in black--the lines are only printing half of the line. In other words, cutting the words in half horozontally
Try cleaning the cartridge by taking a damp paper towel and wiping the ink jets. If you still get the problem, try running the cleaning cycle. If nothing works, then try a new cartridge.
Mar 06, 2009 | Canon BubbleJet i550 InkJet Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
832 people viewed this question
Clive
Clive
Thomas F. Schneider
