Question about Multitech Systems MultiModem II MT2834BL (354519)
There is an Error 692 : There is hardware failure in your modem.
Error 692 Displays When I Try to Connect Dial Up Connection Via My Bluetooth Phone, I Have Bluesoleil Software And T Link Bluetooth Dongle,
I Am Using Sony Ericsson R300 Model .
Pl . Help Me As Soon As Possible.
  • Anonymous Mar 31, 2009
    Error 692
Dear!!!
Error : Hardware failure in port or attached device.
Solution :
1. Check to make sure the correct modem is selected in the dialer.
2. Make sure there are not multiple modems installed.
3. Uninstall and reinstall the modem.
4. Make sure that no other programs are using your modem. Fax software, Supervoice, etc...
5. Ctrl-Alt-Delete, if you see RNAAPP loaded,
6. Send to manufacturer?
Posted on Dec 16, 2008
I know this post is old but i had that problem and after searching a lot, finally i solve it by myself. go to device manager, modems, on your modem or mobile modem right click and click properties. now go to "advanced" tab now that field of extra initialization commands must be clear, if not, clear it. now you can connect without "error 692"
Posted on Jun 27, 2011
Im trying to use PDAnet with bluetooth I have the bluetooth card installed on my laptop tuning vista, and it has an error that says that I need to install the bluetooth software for the phone, and I've...
Make sure you have bluetooth on on both, and that you are connected via bluetooth to your computer.
Turn on pda net on your DI and enable bluetooth dun.
Now go to your bluetooth settings on your computer and double click on your device, a new service should pop up allowing you to enable dun/modem and select that.
right click on your di bluetooth connection on your computer and create a dial up modem.
select the generic bluetooth modem, not the pdanet modem.
Type 123 in the phone number and leave the username and password blank and click connect.
Now you can right click on your DI bluetooth icon on your computer and select connect to the modem connection you just created.
After using my DI as a modem over bluetooth there are a few things to consider.
1. yeah it works great.
2. Its a battery **** fest.
Constant 3g with constant bluetooth = constant battery draw.
I would still recommend using your pdanet via the usb cable, seeing as this will keep the battery level charged, as well as same speed!
Aug 29, 2011 | Motorola Mobility Droid X
Tip
How to set up you cell Phone to connect up to the Internet via USB Cable, IR,...
To set up you cell Phone to connect up to the Internet via USB Cable, IR, or Bluetooth
Go to the website of your phone's manufacturer. Find the support section and locate the modem driver for your phone. If you were provided with a driver disk along with your phone, copy the modem driver from the disk onto your computer. If you were provided an executable file (.exe), a file that runs an installation program, then skip ahead to the "Creating the Connection" portion of this tutorial.
Go into the phone's menu and activate the modem. Since activating the phone's modem function varies from phone to phone, consult your user's manual for instructions on activating the modem.
After the phone is set to function as a modem, connect the phone to the computer via the USB cable, Bluetooth or IR. You will receive notification from your computer that new "hardware was found." You will be asked if you would like your computer to find drivers for you phone automatically and you will also be given the option to specify the location of the driver. Choose to locate the driver and point the installation menu to the folder containing the driver.
Go to the "Start Menu" and open the "Control Panel." Once the "Control Panel" is open, click on the "Network" icon and, from there, select the option "Set up a Connection or Network."
Choose the option
Choose the option "Set up a Dial-up Connection."
You will be presented a list of different connection types, choose the option "Set up a Dial-up Connection." In the next window, enter #777 into the box labeled "Dial-up Phone Number." While the access number #777 works with most carriers, check with you carrier if you encounter access problems.
You do not need to enter a Username or Password unless directed by your wireless provider. Create a name for your connection and enter it in the box labeled "Connection Name."
In the Taskbar, right click on the connection icon and choose disconnect to end a session.
Click connect at the bottom of the menu. You should be authenticated and connected within a matter of seconds. If you need to re-establish a connection, your connection will appear in the "Network" menu inside of the "Control Panel."
on Feb 18, 2010 | Cell Phones
Tip
Using a Cell Phone to connect up to the Internet via USB Cable, IR, or...
Choose the option
Sir I have Chang Jiang W007 Model mobile. I want to connect it to PC via Bluetooth and Cable. Please help. While connecting via bluetooth, i receive "DUN PROFILE DISCONNECTED'" MESSAGE. and while...
Sir I have Chang Jiang W007 Model mobile.. by accidently , the first SIM incoming calls barring password was blocked . also my phone charger unit also failed.. Is there is any solutions for my problems..pls send it to my email ID akgopal2005@gmail.com advance thanks..
Sep 01, 2010 | Cell Phones
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
Not able to access internet using samsung corby s-3653 as modem connection to pc
have you tried configuring your internet access through your samsung pc studio? if not, open your pc studio, connect your phone and create an internet access through internet connector and try to connect.
one way to check if you can connect to inet by using your phone as a modem, is, surfing the web first using your samsung corby's web browser.
if you can't connect or surf the web by phone browser, it means you still haven't configure your browser profiles to your network provider. ask the right configuration from your network and configure the browser profile first.
good luck..
Feb 26, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
I have s dell studio 15 laptop. i got a dell conexant rd02-d400 modem so i could use dial up with it. now i get errors that say it can't connect, but that everything os ok.. error 692 and 618 (i think)...
hello,
Connect your modem to the phone line and test the modem.
Control Panel-->>Phones and Modems. Click icon. Tab Modem. Highlight your modem, and Click Properties--->>Diagnostics. Verify that everything is OK.
Then Start --->>All Programs -->>Accessories-->> Comunications ---Hyperterminal.
Enter a name for a bogus connection, Click OK
Enter your phone number and dial it. If Phone/Modem connection is OK, you shoul hear the busy signal.
Alternative:Run the Dell diagnostics.
If Modem connection is correct you must then create a dialup connection.
Hope it helps.
Sep 12, 2009 | Dell Computers & Internet
Modem problems
Try unistalling and reinstalling the modem drivers.
Nov 03, 2008 | HP Compaq dx2000 Microtower PC Desktop
Hardware failure in a modem error-692 in samsung explore
try go to your control panel open phone and modem delete the samsung modem in there and re install it.
Feb 10, 2008 | Cell Phones
Computers & Internet Logo
8,006 people viewed this question
Top Multitech Systems Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
