Special useage fujitsu m2537m-19B
Hi there, I need to know the jumper settings, and the correct way to install a connecting wire from a fujitsu m2537m-19B to a data acquisition card. The Ribbon cable and the power harness are hooked up in the usual way, but there are two wires, black and white, that need to be connected to the floppy. Here's where they're approximately supposed to go, but I'm pretty sure that someone has played with them a bit, since the ribbon cable was on backward.
st2
x x 3
x x 2 DS
DG .o o o o 1
RY o o o o 0
The o's represent pins, the x's are bare solder spots with no pins, and of course 0,1,2,3 are pin designations that must have some meaningful purpose! This cluster of pins, etc is right next to the power connector. The pin in row DG, marked "~" traces back to pin 34 on the connector for the Ribbon cable. The pins in the second column of rows DG and RY trace back into the main part of the unit, and the left pins in DS, o0, o1, o2, o3, and the right o3, all trace back behind the floppy connector between pins 10 and 20, where they meet up with a bunch of little resistors marked 102. I know this is a big hassle over a stupid floppy drive, but it is for a smog machine and must be booted from the floppy. I've tried other drives but they don't work because of the proprietary nature of the machine. !!!!!!!!!!!!!! By the way I'm assuming that this is a 1.44 mb drive. Thanks a million.
MalcolmCal.: 1.44MB 3.5" Floppy Drive
Positions: DS 0123 + DG RC ST2
Both use Jumpers: 1-1 + 1-1
KISS: (Keep it Simple)
Posted on Aug 06, 2010
Suddenly problem showed, idle at 1000 rpm (know that normal is 600), traction off light, loss of power, stopped running after few mins. NO Check engine light came on!!!
You should take it to a ASE certified repair shop that has the diagnostic equipment to check it out , an I don't mean a code reader . I mean a factory scan tool that can look at engine sensor data PID'S ! It Just stopped running ? Will it start right up again or is it dead . Check for spark , that means pulling the Ignition Coil Housing an using special tool J 36012-A , there just plug wires . Install a J 26792 Spark Tester on #1 spark plug jumper wire. Connect the #4 jumper wire to a good ground. Connect the other jumper wires from the 2-3 ignition coil to the respective cylinders,Connect the J 43298 Igniton Module Tester to the ICM.
Do a fuel pressure test ! With the Factory scan tool check the idle air control valve counts , an see if it can be controlled . 220 K miles , ever have timing chain replaced ?
Oct 14, 2015 | 2004 Chevrolet Cavalier
Ignition timing for 1989 toyota corrolla
1988-95 MODELS
See Figures 6, 7, 8, 9, 10 and 11
This service procedure is for setting base ignition timing. Refer to underhood emission sticker for any additional service procedure steps and/or specifications.
These engines require a tachometer hook-up to the check connector-see illustrations. NEVER allow the tachometer terminal to become grounded; severe and expensive damage can occur to the coil and/or igniter.
Some tachometers are not compatible with this ignition system, confirm the compatibility of your unit before using.
  1. Warm the engine to normal operating temperature. Turn off all electrical accessories. Do not attempt to check timing specification or idle speed on a cold engine.
Fig. Fig. 6: Attach the tachometer to the battery and check connector terminals
  1. Connect a tachometer (connect the tachometer (+) terminal to the terminal IG- of the check connector) and check the engine idle speed to be sure it is within the specification given in the Tune-Up Specifications chart or underhood emission sticker.
  2. Remove the cap on the diagnostic check connector. Using a small jumper wire or Special Service Tool SST 09843-18020, short terminals TE1 (test terminal No. 1) and E1 (earth-ground) together.
  3. If the timing marks are difficult to see, shut the engine OFF and use a dab of paint or chalk to make them more visible.
  4. Connect a timing light according to the manufacturer's instructions.
Fig. Fig. 7: Early type of check connector and SST tool (jumper wire) for base timing adjustment
Fig. Fig. 8: Using the SST 09843-18020 or a jumper wire, connect terminals TE1 and E1 of the DLC1 (also used on OBD-II)
Fig. Fig. 9: Ignition timing marks 4A-GE engine-note the small notch on the pulley, this is the mark to align with the degree scale
Fig. Fig. 10: Timing marks 4A-FE and 7A-FE engines
  1. Start the engine and use the timing light to observe the timing marks. With the jumper wire in the check connector the timing should be to specifications (refer to underhood emission sticker as necessary) with the engine fully warmed up (at correct idle speed) and the transmission in correct position. If the timing is not correct, loosen the bolts at the distributor just enough so that the distributor can be turned. Turn the distributor to advance or ****** the timing as required. Once the proper marks are seen to align with the timing light, timing is correct.
Fig. Fig. 11: If necessary, loosen the 2 mounting bolts and turn the distributor to adjust the timing
  1. Without changing the position of the distributor, tighten the distributor bolts and double check the timing with the light (check idle speed as necessary).
  2. Disconnect the jumper wire or Special Service Tool (SST) at the diagnostic check connector.
This jumper will be used repeatedly during diagnostics in later sections. Take the time to make a proper jumper with correct terminals or probes. It's a valuable special tool for very low cost.
  1. Refer to the underhood emission sticker for timing specification and any additional service procedure steps. If necessary, repeat the timing adjustment procedure.
  2. Shut the engine OFF and disconnect all test equipment. Roadtest the vehicle for proper operation.
Nov 14, 2012 | 1989 Toyota Corolla 2 Door
How to change the battery on a Hyundai Sonata
When you remove the battery to install a new one then you need to enter a radio code to get your radio working again. This is an anti-theft locking system.
To avoid reprogramming your car/radio etc. connect another battery with jumper lead to the battery leads on your car to maintain your car's settings when you disconnect the old battery from your car.
Install the new battery and connect the car's battery leads to the new battery. now you can remove the jumper leads and the second battery.
WHEN YOU CONNECT THE JUMPER LEADS, MAKE SURE YOU CONNECT POSITIVE TO POSITIVE AND NEGATIVE TO NEGATIVE.ON BOTH BATTERIES.
Oct 19, 2012 | Hyundai 2006 Sonata GLS V6
Start problem
All I see for the heading, romakavati, is - Fujitsu Barebone Systems.
Do I assume we are talking about a barebone Desktop Computer?
If so;
1) The plastic front of the desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front panel go to, is the Front Panel header.
Do you have the wires from the Power On switch, connected CORRECTLY, to the Front Panel header?
(The Power On switch is located inside the plastic Power On button assembly. It is a style of ATX power on switch.
This is one example,
http://www.directron.com/atxswitch.html )
2) Your motherboard may require a 4-pin ATX +12 Volt power cable.
Example of cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for the Processor.
If your motherboard does require it, do you have it plugged in?
3) Do you know if the Power Supply is good?
Even if it is a new one, and came with the barebones computer you bought, it doesn't mean it is a good one.
May be a bad one, and doesn't even turn on.
May be a bad one, and one of the three main voltage power rails, is no good.
[ There are three main voltage power rails, in the Switched-Mode Power Supply, installed for your Fujitsu desktop computer.
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail
All are DC Voltage.
{In comparison two D cell flashlight batteries store 3 Volts DC. Just a fact you may be interested in ]
First see if the Power Supply will turn on. This is done with a jumper wire, on the Soft Power On wire, in the ATX main power cable's connector.
Your ATX main power cable may be a 20-pin ATX main power cable, or a 24-pin ATX main power cable,
A) 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
B) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
With both power cables you will see there is a Green wire.
This is the Soft Power On wire.
Abbreviated as PS_ON.
A jumper wire is used to briefly connect the Green wire, to ANY Black wire.
ALL Black wires are Ground wires.
DO NOT cut the wires, or poke a hole in their insulation.
The preferred jumper wire is a paper clip.
The paper clip is straightened out _________________
,then bent into a U-shaped.
The middle of the U is wrapped a few times, with black plastic electrical tape. This area is for your fingers, and thumb to hold onto.
U-shaped jumper wire turned upside down, you have two 'legs'.
The legs go down into the socket holes, of the ATX main power cable's connector.
Let's look at the example for the 24-pin ATX main power cable, again,
The 24-pin ATX main power cable needs to be plugged in, as shown in the photo to the far right.
Computer power supply is plugged into power.
One leg of the paper clip jumper wire, is inserted down into the socket hole, RIGHT NEXT TO the Green wire.
Goes down in the socket hole, slides past the insulation of the Green wire, and touches the metal terminal at the end of that wire.
The leg of the paper clip jumper wire, MUST go down in the socket hole far enough, to TOUCH that metal terminal end.
[ Metal terminal is a type of female Molex terminal. Tube shaped, and goes over a contact pin in the motherboard connector,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US ]
The other leg of the U-shaped paper clip jumper wire, goes down into
ANY socket hole, that has a Black wire in it.
The contact made is no more than 2 seconds.
(The Power On switch is a Momentary Contact Switch)
IF, the Power Supply comes on, you either have a bad Power On switch, or it is Not connected correctly, in the Front Panel header on the motherboard.
IF, the Power Supply does Not come on, you have a bad Power Supply.
Plain, and simple.
IF, due to lack of a more detailed statement from you, that your problem is the Power Supply DOES come on, but Windows does not load;
A) You know the Window operating system is NOT on a new harddrive, right?
You have to install Windows on it.
B) Installing a harddrive with Windows already on it.
You know that when Windows is installed on a computer, (To the harddrive, actually), it assigns hash values to certain major components, right?
Certain major hardware components such as;
1) Processor
2) Motherboard chipset
3) BIOS program, and version.
4) Harddrive
5) Graphics chipset
Change any two, or more of these components, and Windows will want to be activated again. (Not registered,... Activated)
This is because Windows will 'think', you are taking it off of the harddrive it is on, and trying to install it on another harddrive, or computer.
Microsoft User's License states; "One GENUINE copy of Windows per
ONE computer"
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
However, the Windows activation screen does NOT always come up.
Ready for your questions, and additional information you did not post.
Post in a Comment.
Regards,
joecoolvette
May 20, 2012 | Fujitsu Computers & Internet
Ok here is an update... the crank sensor is about 3 volts dc. taking the starter relay out bike will not turn over. I have compression both cylinder.... Have gas going in to the carb. I have 11.6 volts...
Ok, I assume that you are talking about the large spark plug wire connections on your coil. The book says that the resistance should be 10,000 to 12,500 OHMs. I would assume that is between the two towers as it does not show the lead connections.
Here's how I test a coil. Turn the switch on and check for 12 volts on one end of the coil. Have a set of plugs in the wires and have them grounded well. Disconnect any wires from the other small connection and connect a temporary jumper wire. Momentarily ground the jumper wire and then remove it from ground. Each time your REMOVE the short jumper wire from ground, you should get a spark from the spark plugs. If not, make sure you still have the 12 volts on the other end and the plugs are well grounded. If this correct and you do not get a spark, your coil is bad.
Feb 14, 2010 | 2003 Harley Davidson FLSTC Heritage...
Just installed the honeywell thermostat. the ac turns on, but not the heat. what do we do?
Some of the thermostats from Honeywell require a jumper wire on the thermostat between the RC and the RH connection for the heating to operate. It is possible that your installation needs this jumper wire installed for the heating to work.Verify that this jumper wire is installed if your thermostat requires it. If it requires the jumper wire and you do not have one you can cut a small piece of existing wire on the connections to make a jumper wire. There are also some thermostats with a jumper switch for electric heat and gas heat...make sure that it is on the proper setting.
Dec 02, 2009 | Honeywell Electronic Programmable...
I have a fijitsu lifebook E2000, in order to install a hard drive, there is a special adapter that goes on the IDE interface on the hard drive that allows the hd to connect to the motherboard. do you know...
Ask your manufacturer Fujitsu for that special accessories so that what you can purchase is 100% compatible to your device. You can browse the website for info as well.
Nov 25, 2009 | Fujitsu Siemens LifeBook E2010 Notebook
Installed new optical drive. Mac won't boot with optical drive connected to the IDE cable. Boots fine with the optical drive disconnected. Tried another cable, no joy. Tried another new drive, same issue....
there is a little jumper on the back of the drive .. that has to be set correctly .. if your hard drive is set as a master (almost always is) then your optical dirve has to be set as a slave .. look on the drive and a pictorial will show you how to set the jumper correctly .. or just put the jumper on the same way the original drive was set ..some computers use "cable select" .. thats where the cable itself is wired in a special way that sets up the drive .. also make sure the cable is not plugged in to the device off one pin .. left, rigtht or up, down .. make sure its not plugged in upside down .. there should be a key that prevents that but it can be forced ..
Nov 12, 2009 | Apple iMac G4 Desktop
I cant reset the bios password on a fujitsu lifebook n6410
You can find bios clear jumper on motherbord most of it is near cmos cell.
Put it to 2-3 position then power up then again put it in original position 1-2
then check.
Also you can reset all settings with pull out cmos cell for 15 minutes then it not need password.
Try again.
If you need more assistanse let me know.
Thanks.
Aug 24, 2009 | Computers & Internet
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
