Question about HP Officejet 4355 All-In-One InkJet Printer
1. Out of paper. 2. Unable to scan, copy or sent a fax.
1. When I try to make copies, thing like this will appear, 'unable to scan, copy or sent a fax'. Press Ok.
2. When I try to print, thing like this will apperar, 'out of paper'.
Refer to device documentation to troubleshoot
Posted on Jun 09, 2010
Cartridge error
Posted on Dec 19, 2008
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Ink system has fail. unable to copy receive faxes, or print. Refer to printer documentation. Error: 0xc18a001
i can not feed paper at all or copy to paper but i can scan files to my computer how can i fix this
Mar 01, 2009 | HP Photosmart 3210 Printer
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to copy
You need to open the cover and see the document you were trying to fax.Just pull it gently.
Samir
Feb 21, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
352 people viewed this question
Seeker5211
Seeker5211
