Question about Toshiba Satellite M100 Notebook
Laptop satellite m100 will not start up suddenly
The hard drive light come on for less that 1 second and the lcd sreen remain dark. Is the hard drive defective? What could this be?
  • 3 more comments
  • Anonymous Jan 05, 2009
    I have the same problem on 21 dec.
    I fixed it temporarily in connecting a slave VGA monitor and removing the battery. When it start, the bios screen (Phoenix) appears on the VGA monitor, then XP start.
    The monitor of the laptop stay black until the start of the blue windows screen appears.
    I have been infected by a virus, called 2u.com. I reinstalled windows and then the problem appears. Maybe the bios was affected
  • Bud Franklin Aug 03, 2013
    too complicated for me ... I did just replace the screen but problem was there before
    I had burned a photo disk from an SD card now it shows as opened in my pictures I can't get rid of it
    that is when storage use doubled
    running Diags shows all ok no infection by system Mechanics
    Sergeant:
  • 324 Answers
Try the following things and try to bring it up after each action:
1) Remove and reinstall your memory module(s)
2) Remove the CD drive, any PCMCIA cards, flash drives, all but 1 memory module and anything else that you might have connected to te system.
3) Remove the hard drive and try to bring the system up. You should get a message that sez something to the effect that the OS can't be found.
Let me know what happens and we'll go from there.
Thanks, and have a good one!
Ron
Posted on Dec 14, 2008
The screen on my toshiba satellite a135-s2386 has a red hue for the second that it remains on during start up. It will display fine on an external monitor. If an external monitor is not connected, and you...
This sounds like a problem with the back light. The back light is generally a small cool fluorescent light. The problem could be with either the fluorescent light or the inverter board that supplies the voltage to run the lamp. If you are able to disassemble it yourself you can usually buy an inverter and lamp online. This requires a good amount of dis-assembly and expertise but costs less. At a higher price but less expertise is a complete lcd display including frame and covers. This basically just requires removal of the top cover of the laptop to access the screws that hold the display on and access to the cables.
Best of luck, Jim
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellllite m100 suddenly shut off after using it for half an hour to an hour
Is it getting hot? If so it will shut itself off to prevent damage and probably needs the fan cleaned out to improve airflow.
Apr 07, 2011 | Toshiba Satellite M100 Notebook
Laptop toshiba satellite p200 bw5 screen goes dark as if darkness/brightness was adjusted - but not Thanks
An LCD screen cannot produce enough light by itself. It needs a Backlight to help illuminate the screen.
Power for the Backlight is produced by an Inverter. An Inverter also provides power for the LCD screen.
It reduces voltage for the Backlight, and increases Voltage for the LCD screen, from the laptop's power.
Most of the time a dark LCD screen can be attributed directly to a bad Inverter. (Around 90 percent)
A Backlight is a CCFL.
Cold Cathode Fluorescent Light.
VERY similar to the fluorescent lights you see used in residential, and commercial applications.
(Homes, and businesses)
Only on a MUCH smaller scale in physical size, and needed power to operate.
When a Backlight goes bad, it just goes all at once. Not goes dark as you have stated.
(Your statement meant to me that you power on the laptop, the LCD screen shows well, then goes dark)
How to install an Inverter in a Toshiba Satellite P200 series laptop,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p205/take-apart-display-panel-1.htm
(You can click on each individual photo to enlarge. You are on Page 1. Page 2 is accessed at the bottom, by clicking on it. Page 1::Page 2::Find another model)
Just one of many places that offers an Inverter for your Satellite P200.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=5367&zenid=43bc1e775a9ed2d4309140111231cab5
NOTE*
1) ALL power removed from the laptop before beginning.
AC adapter (Charger), and Battery.
2) The screws you will remove, may have screws that look alike, but are NOT.
Do Not mix them up.
For this reason it is suggested to use a multi-compartment container, and label the compartments for where the screws came out of.
You can use a clean egg container, and label the individual egg holders, in a pinch.
IMHO it isn't hard to perform this repair, and you can do it. Save yourself money.
For additional questions regarding this, or comments, please post in a Comment.
Regards,
joecoolvette
Oct 22, 2010 | Computers & Internet
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
Irregular power supply to toshiba satellite M100 laptop
hi there,
i would like to know how old is your laptop.?
new laptop less than a year can operate on 1- 3 hours.
older laptop 2yrs above can only operate at 1 - 1 1/2 hours.
first for an initial help try removing the battery pack and put it back in properly,
let me know again here.
thanks
Dec 06, 2008 | Toshiba Satellite M100 Notebook
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
HP Pavilion, Screen working, but extremely dark!
As per your description, I find that the issue is with the LCD Backlight which is also called as LCD Inverter which lights up the LCD to show us the Display on the LCD Display.
If this Backlight is gone bad, you will be barely able to see the Display on the LCD.
Coming to the Noise you had mentioned above can be from the Cooling fans of the Notebook which will be spinning at high speed when the Notebook starts and will reduce gradually after few minutes.
I recommend you to try cleaning the Cooling fan vents using any Vacuum Cleaner or Air Blower.
I recommend you to contact any nearest HP Authorized Service Center and get the LCD Backlight replaced.
Hope this helps....
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Toshiba satellite monitor problems
Sounds like the memory module is bad. Return it or get a warranty replacement.
Aug 14, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
