My Toshiba keeps on overheating and then shuts down. what is the problem????
    Problem Solver:
  • 7 Answers
Make sure fan is working,clean the dust from it if necessary, make sure it is sitting and a hard surface where air can move to escape from the machine aswell as air getting in the machine
Posted on Dec 14, 2008
My l500 1xd toshiba keeps shutting down
First guess. Overheating. You can check the Event Viewer for actual cause. Though the explanations can be very technical.
A simple procedure would be to blow out the vents / fan with canned air. It really makes a difference.
Just a thought. What about power setting? Disable Hibernation and or sleep. Are you referring to this?
Oct 25, 2012 | Toshiba Satellite L500-1XD WXGA HD 15.6"...
Toshiba sattelite a665 keeps shutting down
Hello i think you have a overheating problem.
The problem can be solved by cleaning the cooling element that cools down the cpu.
Its probably blocked by dirt.
I do sometimes have luck cleaning it with compressed air but you should BE CAREFULL not to harm the mainboard.
I do sometimes also remove the cooling element and give the cpu new cooling paste.
If you not have tried that before it should be a task for a computer repair guy.
Good luck
Sep 09, 2012 | Toshiba Computers & Internet
My Toshiba Satellite M205-S7452 laptop keeps automatically shutting down. I'm guessing it's caused by overheating.
Most likely this is an overheating situation.
If your CPU is running at over 60 degrees you might be at risk of burning it out. Some systems shut down automatically when the temperature reaches an unsafe level.
If you determine that overheating is not the problem, the most likely suspect is bad memory. The best way to find the culprit is to pop open the system unit, remove (or replace) one RAM stick and see if the problem is solved. Run your system for a while and if the problem goes away, you win!
If not.lather, rinse and repeat for each RAM stick until you find the one that's misbehaving.
Jan 19, 2010 | Toshiba Satellite M205-S7452 Notebook
My laptop keeps shutting down at random times. I
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Video Quality Problems
Hey,
the laptop is overheating and shuts down to prevent hardware failure. Use canned air to blow dust out from the fans that may improve it a little.
Feb 18, 2009 | Toshiba Computers & Internet
My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
Aug 06, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
Nov 18, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
