Question about Nintendo Wii Console
ROUTER CONNECTION I PUT IN EVERYTHING I NEEDED FOR MY ROUTER ON THE MAIN SETTINGS AND IT STILL DOESN'T WORK. IS THEIR A WAY I COULD CHANGE MY ROUTER TO ALLOW MY WII TO ACCESS IT
    Problem Solver:
  • 8 Answers
Turn off the wep-key... check your ssid... or move the wii closer to the router... Hope That Helped
Posted on Dec 15, 2008
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Tip
How to set up router
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for step bi step instructions
on Dec 03, 2009 | Computers & Internet
Connected to wifi but it can't browse
You may have a local area connection only. This means that your PC is connected to the router but the router is not resolving web page addressess. The simplest thing to try is resetting the router by unplugging it from the mains, leave for 10secs or so and plug back in, this should get you back online. If this doesn't work, put the router back to factory settings. There should be a small hole on the back of the router to do this. With the router powered up, insert a thin peice of metal in the hole and press until all the lights go out and then release. You will need to enter all of the setup info again by doing this (user name, password, IP etc).
Mar 21, 2012 | eMachines eM250-1915 Netbook
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
My Hawking 801 is 2 years old. It has started losing its configuration. I launch the set up CD, follow the instructions, put it within range of the main wireless router and in less than 30 minutes it...
First thing you need to do is setup the IP, Subnet Mask, and Gateway of
your extender. Before any connection of the extender, we have to find out the IP of the router. Start Menu Run Type "cmd", hit enter In the black command prompt window, type "ipconfig" The ###.###.###.### to the right of default gateway is the IP of your router.
For example...192.168.1.1
Now you can either connect the extender directly to your computer or
to the router.
Use the wizard to find the extender and to change the information of your
extender to...
For example based upon the above #...
IP: 192.168.1.*** (Subnet: 255.255.255.0
Gateway: 192.168.1.1 ( The *** can be any # up to 250 except for the routers...typically we use 235.
After the wizard saves and reboots the print server, connect it back to the
router or leave it there.
Then open up your Internet Explorer and in the address bar, put in the
Address of the router in (192.168.1.235).
It should come up and ask your for the username/password (admin/1234) if it
doesn't then power cycle the device.
On the main page of the extender, fill in exactly the wireless
settings of your router here.
Make sure you fill in...
SSID Channel
Encryption
After you save, you should be able to disconnect the extender via lan cable
from the router and use it wirelessly.
link is here
Oct 09, 2011 | Hawking 802.11g Wireless-G Range Extender
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
No internet connection
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
Click here for step by step instructions
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
INTERNT CONNECTION
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 14, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
