Question about Sharp LC-15AV4U 15 in. LCD Television
Channel tuner problems???
We have a Sharp LC-15SH4V.  About 2 yrs old.  We have a few channels that were working that now cannot be accessed.  They appear blacked out.  The remote and channel selection on TV skips over them.  When we manual enter channel number - the black out appears.  We did the channel reset via the set up option.  That actually fixed a few of the blacked out channels but now there are a few new ones that cannot be accessed.  Nothing in the troubleshooting section of the manual on this type error.  Any suggestions on how to troubleshoot?
Thanks!
  • Anonymous Mar 20, 2014
    I have a LEXSOR: LC-32W18SD. But I have no remote. Is it possible to set it up manually from the TV itself?
    Problem Solver:
  • 15 Answers
Probably one of two things..... LOW cable signal and tuner can not pick up the channel... or the tunner itself is bad.
Posted on Dec 18, 2008
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Tv stays on one channel,no color or picture just ghost or outline, i have a Sharp lc46sb 54u
Check the settings to see if it is locked on channel 3 for external tuner source to have an input from a cable box ant in that needs 3 to function or from some other externally decoded signal like a vcr. Does the TV have a Digital tuner or the old analog tuner? If it's digital you can hook up a rabbit ear antenna with the UHF output on it & should be able to tune in some stations. If it's the old style then you will need a converter box to get it to receive any stations.
Fist check the settings to see if it has it set to lock on channel 3 for external tuner source.
Apr 03, 2013 | Sharp Aquos Televison & Video
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Samsung plasma TV tuner dropped a channel.
you can try a rescan of your channels if that does not work then you will need to rplace the mainboard iam assuming your NOT using a cable box
Dec 07, 2009 | Washing Machines
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Sharp LC-32GD9E
Is this TV connected to a digital box or directly to an antenna? If its connected to a box then suspect the box first. If the box has been swapped with another one and still does the same thing, then the TV has a bad tuner and/or digital board. The tuner in most TV's is part of the digital board and must be replaced together.
Jun 09, 2008 | Sharp Televison & Video
Volume and channel control on TV not working
The control board is defective. Is in warranty so call Sharp to have it fixed.
Dec 29, 2007 | Sharp LC 37D62U 37 in. LCD HDTV
Some channels do not have sound.
Try the MTS button or audio button and make sure that it is set to either mono or stereo and NOT SAP.
Nov 30, 2007 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp 36K-S400
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Nov 17, 2007 | Sharp 36K-S400 36" TV
Sharp LC-15AV4U 15 in. LCD Television Logo
185 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
