Question about Dell Latitude 110L Notebook
Keyboard keys swapping commands
I conacted you yesterday but the problem was not resolved I tried the system restore and installing the drivers you recommended but did not solve the key swapping problem
  • mathew1234 Nov 19, 2007
    when I press certain keys i.e m I get mn when I press c I get cv etc not all keys are affected
    President:
  • 2,961 Answers
Sorry you still have a problem with the keys. Try this key remapper download to correct the keys, if still no change then it may be a new keyboard is required. http://webpages.charter.net/krumsick/
Posted on Mar 14, 2007
MSI U100 FUNCTION KEY COMMANDS NOT SHOWING ON SCREEN ANYMORE
That is quite common and can be windows updates or spurious downloads that corrupt the system files. Restoring the complete system will bring it back but it may be something to do with either the system drivers or keyboard driver. Try downloading fresh drivers from msi.
Jan 31, 2014 | MSI Wind U100-030US Laptop
Tip
How to run System Restore from the Command Prompt?
Here's how:
  1. Restart your computer to boot your system in to Safe Mode.
  2. Go to Start>> Turn off computer>> Restart.
  3. When the message "Please select the operating system to start" appears, press F8.
  4. Using the arrow keys, highlight the option "Safe Mode with Command Prompt" , then press <Enter>.
    Note: If your system is a dual-boot or multi-boot system, choose the appropriate installation using the arrow keys, then press Enter.
  5. Be sure to log on to the computer with the account that has administration privileges.
  6. Enter the following in to the command prompt: %systemroot%\system32\restore\rstrui.exe
  7. Press <Enter> on your keyboard.
  8. Follow the onscreen instructions to restore your computer to an earlier state
on Jul 05, 2010 | Computers & Internet
Windows cannot find
will the computer boot to an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
My keyboard is not showing in device manager
To install your keyboard or mouse:
  1. Exit Windows and turn off your computer.
  2. Unplug the power cord and modem and network cables.
  3. Disconnect the old keyboard or mouse.
    If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
      If you are installing a PS/2 keyboard, connect the keyboard to the PS/2 keyboard port on the back of your computer.
      1. Connect the power cord and modem and network cables.
      2. Turn on your computer.
        To install the device driver from the Gateway System Restoration Kit:
          1. Start your computer. The Add New Hardware Wizard window opens.
          2. Click Search for the best driver for your device, then click Next. Complete the wizard by repeatedly clicking Next until the wizard tells you that it was unable to detect any devices and that it has installed an unknown device.
          3. Insert Disc 1 of the Gateway System Restoration Kit into the CD or DVD drive. The System Restoration Kit program starts. Go to Step 6.
            - OR -
            If the program does not run automatically, go to the next step.
          1. Click Start, then click Run. The Run dialog box opens.
          2. In the Open text box, type d:\autorun.exe (where d is the drive letter of the CD or DVD drive), then click OK. The System Restoration Kit program starts.
          3. Click the Install Hardware tab.
          4. Click the device driver, then follow the on-screen instructions. Installation is complete. If your keyboard or mouse does not function correctly, see "Troubleshooting".
        1. The keyboard does not work
          bdgreen2.jpgMake sure that the keyboard cable is plugged in correctly.bdgreen2.jpgRemove all extension cables and switchboxesbdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgClean the keyboard by using an aerosol can of air with a narrow, straw-like extension to remove dust and lint trapped under the keys.bdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgReinstall the keyboard device driver. For more information, see Installing the device driver.
          A keyboard character keeps repeating
          bdgreen2.jpgMake sure that nothing is resting on the keyboard.bdgreen2.jpgMake sure that a key is not stuck. Press each key to loosen a key that might be stuck, then restart your computer.
          Liquid spilled in the keyboard
          bdgreen2.jpgIf you spill liquid on the keyboard, turn off your computer and turn the keyboard upside down. Let the liquid drain, then let the keyboard dry before trying to use it again. If the keyboard does not work after it dries, you may need to replace it.
Jun 30, 2012 | Gateway 7001433 Keyboard
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
I just got my asus G73Jw, and my keyboard dosen't light up, none of my fn keys don't work, neither does my enter key
SOLUTION by Arun Sangal
1. As said by others above, if its just that you have turned the lights completly off.. then press "Fn" key + F4 key (keyboard light increase) button.
2. If the above doesn't do anything or-- if Fn key + any other F? key (like F11/F12) for sound decrease/increase don't do anything ... meaning your FN key driver is messed up, then dont worry, See Hannah Montana and relax.
After seeing it, go to your computer desktop, there you'll see, "e-driver" shortcut/icon. Click it and you'll see a new pop-up window. In this windows, ASUS various ACPI/etc drivers will "AUTOMATICALLY" download (provided you are connected to internet) and it's fast.
I did the same, and system automatically restarted/rebooted during the "e-driver" update process. Finally I restarted my system/laptop (G873JW) and "HOLY HYENAS".... my system is running like a pony ***. AWESOME, it worked for me and my problem got resolved.
NOTE:
1. In case you dont see "e-Driver" icon on your desktop, then usually the file is stored at "C:\eSupport\eDriver\InstAll.exe" on my laptiop. Try runing the above file from "Windows" command prompt or double clicking on this file by going to "C:\eSupport\eDriver" folder and double clicking on "InstAll.exe" file.
GIGA, you should be good to go with this FN problem on ASUS G73JW or any other series of laptop.
2. During the update process, if you see "ASUS live update" green color window comes up and starts downloading something, hang on, look at it if it's doing anything, if it does some download and hangs at the particular point (i.e. downloading not progressing), then, you can cancel it. BUT make sure the update pop-up window that came after you clicked / ran "e-Driver"/InstAll.exe file, that should complete successfully.
Good luck.
Once the keyboard "FN" key problem is resolved, then you can go to their site and see if they have any updated version of drivers for your video/blah/blah ... thingies.
cheers, Arun Sangal
Dec 23, 2010 | ASUS 90-A4C1K1000 Keyboard
''HP Pavilion dv7-1183CL Laptop Keypad Issue'' Keypad/NumberPad/NumPad is randomly slow, stuck, or disabled. The Keypad will not stay enabled. Holding down a number on the Keypad and pressing the Fn Key...
a new keyboard? or maybe the cable end inside is loose?
in ebay type, dv7-1183cl keyboard, see em,?
or read the manual called service, on that pc, at HP.com
see the 100 keyboards for 100 languages? yah.
one is yours, find it write down the P/n for yours
back to ebay and find it.
or ask at HP.com not here, we are not hp.
its that or virus infected.
we boot to a linux or windows PE live disk or stick
if the key works now, then you learned in 5min work
the problem is our unstated OS. is corrupted.
why not have tech, just fix it.?
May 30, 2017 | HP Computers & Internet
I am having some problem with my keyboard some part of it are working properly why some are not..and am trying to download the drivers on the net but i can get it the model is dell laptop pentium3
You need to uninstall the keyboard drivers to solve this.
Please perform the following steps to get in to device manager.
1. Press "Windows" key and 'R" simultaneously to open the command window.
2. In the open dialog box type 'devmgmt.msc' and hit Enter.
3. A Window with the name 'Device Manager' opens.
4. Click on + sign beside the keyboard entry and a list of devices are shown.
5. Right click on the device and select uninstall.
6. Restart the computer.
The drivers are automatically installed from the Operating System after you restart the computer.
If the issue is still there, then enter into BIOS page by pressing F10 key or F2 key on the keyboard when you restart the computer.
In this page select restore all the settings to default. Save and exit.
This will fix the issue.
Feb 18, 2009 | Dell Inspiron 1501 Notebook
Keyboard problem
It may be easier to do so, and you won't lose any saved work on installed programmes and updates installed since you inserted the keyboard. You could try re installing the keyboard and touch pad drivers and if no change carry out the above.
Mar 05, 2007 | Acer Aspire 1362LCi PC Notebook
Dell Latitude 110L Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
