Hi i have a siemenc meter ( model zmb127dr53 - 3 phase) which the meter dose not work but i have electric power. what is the problem?
I have a Bravos XL dryer < than 1 year old. Suddenly it stopped running & the LEDs all went out. There is power at the 250 v outlet but no panel lights or drum light. I am not sure where to start.
Hi Larry
A small cheap MultiMeter would assist here
Allowing you to trouble shoot to where power is lost.
Probe & aligator clip to Neutral or ground
& probe for 240v ac
Caution is essential near we floors
Would also be nice to have a RCD in your meter box for shock protection (ground to active phase)
....unless you've got a heart like horse!
or a portable one plugged in at the wall.
It will only save you from ground to active phase shock
not phase to neutral.
Better safe than sorry
How to Use Multimeter
THE BEST Multimeter tutorial HD
http://www.jaycar.com.au/Test-%26-Measurement/Multimeters
Mar 13, 2016 | Maytag Bravos XL High-Efficiency Electric...
Hi!3-phase motor wires brn/blue/blk no open cct.P.c.b there are no components burnt out or blown.I removed interlock switch and will buy new one and try again.Belt ok.Pump solenoid valve ok .
Check for a motor start capacitor that is defective. This can happen without external symptoms. Highly unlikely Hotpoint washer has 3-phase motor. Most household loads are single-phase. In North American residences, three-phase power might feed a multiple-unit apartment block, but the household loads are connected only as single phase. In lower-density areas, only a single phase might be used for distribution. Some large European appliances may be powered by three-phase power, such as electric stoves and clothes dryers. Three wires could be for different speed ranges or one could be frame ground.
Apr 08, 2015 | Hotpoint Washing Machines
Www eemaxinc com support
My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
Jan 17, 2014 | Water Heaters
Model 9155 display says: "UPS
bypass is not available because your input is going in one phase rotation and the bypass is going another. Both input and bypass needs to be a clockwise rotation. A cheap phase rotation meter will fix this. Call me at Gruber Power Services for free tech. support 800-658-5883 x256 ask for Eric
Aug 23, 2011 | Eaton Powerware 9155 UPS UPS System
How to install a 3phase power meter device
The three phase power meter will have sensors or terminals to run TWO of the three load leads through. In addition you will have a voltage input or two.
The exact connection will depend on the model of your device.
Only two load leads are needed since the third will have the sum of the other two leads (including the phase angle in the sum).
Nov 20, 2009 | Measuring Tools & Sensors
How do I wire a 30amp 3phase 250 volt receptacle for proper phase rotation ie x,y,z on the device with phases a,b,c in the panel?
You will either need a phase rotation meter to identify the rotation, or, if it is a motor, reverse any two leads to spin the motor the opposite direction (this works on single phase, too).
i hope this is helpful
matthew
Oct 31, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Jan 18, 2009 | Welding Tools
Bottom burner in oven dose not work but top burner work why
possible hat the bottom elemnt has burnt out/broken/shorted. you would need to check the element for continuity witha power meter ifits not an obvius break.. BEWARE ALWAYS LIVE WIRELEADING TO THE BAKE ELEMNT TURN OFF POWER FIRST!!!!!!!
Dec 02, 2008 | Crosley CE35100AA Electric Kitchen Range
Optiplex GX520,270,280,755,745 ONBORD COM PORT AFTER DAYS WILL FAULTY
A surge protector stops power surges from eskom etc. from fryin your mother board and power supply. when the power goes off sometimes its just a phase . when all phases are off and the power comes back to all Phases instantly at a strong output this can fry your mother board or damage your power supply . surge protector keeps the power at one level even if it isnt , make sense? Also see UPS.Lightning can do the same effect too
Jan 18, 2008 | Dell OptiPlex GX520 PC Desktop
47 people viewed this question
 Grubhead
Grubhead
