Question about KitchenAid KHGV01RSS Dryer
Dryer run not heat
I have proline front-loading gas dryer KHGV01RSS1 over 1 year old.
Dryer run, but does not heat
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
I have a Maytag Ensignia Electric Dryer Mod. # MDG7758AWW. It starts up but runs cool air only and intermittenly will give off some heat but can run for a hour with cool air only. The vents and lint...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 15, 2011 | Maytag MDG7758AW Gas Dryer
Dryer 'runs', just doesn't develop ANY heat. We
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | KitchenAid Dryers
Ge front load dryer not heating three years old model # dbvh520ej2ww
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Dryers
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My 4 1/2 year old electric Whirlpool dryer runs
If your dryer2_bing.gif is electric2_bing.gif..
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Timer not shutting and and not heating
Hi, Is this a gas or electric dryer? The heating problem is causing the timer not to advance. Let me know which type dryer and I can get you through this.
Vic
May 10, 2009 | Dryers
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
KitchenAid KHGV01RSS Dryer Logo
135 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
