Question about Sony Playstation 3 (PS3) Console
Start up screen
When i start up my ps3 i cant get no memu screen it is just black but you can still hear things going on in back round can you help thanks
  • 43 Answers
Have you tried it on anoother tv?
you see the cable connecting from the tv to the ps3?
make sure the yellow onw is working properly
Yellow=Viewing
Red=Right Sound
White=Left Sound
Posted on Dec 14, 2008
  • no1coolfool Apr 14, 2009
    sorry for mis spelling
Cant hook up my ps3 to the tv ? tried all 3 input outlets and nothing tried hooking it up with a dvd player and still nothing ?
The ps3 has 2 output modes, hdmi and composite or component. For example if you started with composite and switched to hdmi the screen would show up black. The way to select the dif output is to press and hold the power button until you hear a second beep, this should put it on the proper output. Hope this helps and is the only thing I can think of if your tv is properly working.
Aug 23, 2011 | Audio Players & Recorders
My ps3 is the one that plays both ps3 and ps2 games and it says cant start cannot find correct hard drive
1. turn off system completely (this means the switch on the back)
2. hold touch sensitive reset button down till you hear 3 beeps, than let go.
3. hold down touch sensitive reset button until you hear 2 beeps and a double beep.
4. follow on screen directions, choose what option you want (i pick 3, it
seems to work the best)
5. follow on screen directions
http://www.youtube.com/watch?v=c0e-oO6l9kk
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS...
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
My ps3 screen goes black when i start playing games
try changing the resolution settings on the ps3 itself to match your tv because if the tv cant handle 1080p then dont set it to it, going into a game changes the resolution to mach the games rated one
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Everything is connected, i can hear it, but cant see it
The previous answer is partly right. Are you both using HDMI, or are you changing connection method. If you change method, you must reset the graphics settings, which can be a bit tricky without a screen. Turn off your PS3, then Press AND HOLD on the Power Symbol for some time, or until you hear the beeps, and the flight flashes green, then, it should work.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. The corrupted files are about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Indra!
May 30, 2009 | Sony Playstation 3 (PS3) Console
Screen of my ps3 went black, i cant see the menu
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
That's it!
May 13, 2009 | Sony PlayStation® 3 (80GB) Console
My ps3 is not working the screen is just black and cant get any thing from it the ps3 is turend on but nothing coming up on scree can you help me
press and hold power button until it reset
you gonna hear a beepor go to next step:
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
May 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
104 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
