Question about Kenmore 24032\24036 Top Load Washer
Kenmore 110.92282100 won't adjatate with aload.
I ran it with out anything in it and the adjatater worked but if you just touch it it doesn't ???
  • 113 Answers
Does it spin? Or just an agitation issue. Sounds to me like you need a new clutch. The clutch is #5 and costs about 40.00.
Posted on Dec 16, 2008
94 VW Golf Rear cargo door won't open
you might have hit hard to close the door. open door pad n try to open the gate
May 14, 2013 | 1994 Volkswagen Golf
Hi, I have a Kenmore 110.26832692, lately it's been making a loud grinding/thumping noise when agitating. The clothes end up wrapped around the agitator, sometimes even stuck underneath it. The basket...
Sounds like maybe the changing of the dogs might be the problem./The top section of your adjatator sould move freely one direction turn it the other way bottom section should move with it. If it does not do that then your dog install got messed up also you should not barely get fingers under botton section of adjatator/ Note the basket is not supposed to move when washing on this unit . see if unit is doing any of those things get back to us...Good luck
Feb 09, 2011 | Kenmore Washing Machines
My ge washer does not wash, it just spins. Help me fix pls.
if you mean it does not adjatate that would be your adjatater coupler grab adjatater at bottom both sides pull adjatater up it will be hard but it will come. when that comes of you will see adjatater coupler remove bolt in center of it that part will pull up. now to replace that part ge changed it about 2 years ago when you get the new coupler you will need the new bolt. 'GE sells that coupler as a kit comes with the new bolt thats the way to go...if I helped you please vote if you need more help please ask good luck
Feb 08, 2011 | Washing Machines
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
I have something stuck under the adjatator. How
Hi, depending how old you GE washer is will determine how difficult the agitator will be to remove. However, all GE made ( hotpoint, baycrest, some kenmore, moffat, mcClary, etc. ) washer's of the past 50 yrs. or so have agitator's that are pressed onto a drive block and need to be pulled off, sometime's by hand, sometimes by a greater force, i.e. "agi-tamer" or "hammer". ( of course the hammer method will require you to by a new agitator ). The "agi-tamer is a real tool which slides under the agitator and by way of being pressurized with "cold" water ( hot will burst it ) will push the agitator up off the spline/block...don't stand over it looking down or you'll potentially get "knocked out" ha ha ! Hope that help's. At least you know it does "pull off" and it isn't bolted in place. Good luck, macmarkus :)
Feb 16, 2010 | GE Washing Machines
My kenmore washer will not adjate.
You probably have a broken drive coupling. The part is cheap enough. here is a pdf:
http://appliancejunk.com/motorcoupler.pdf
Here is one from Jimbo:
http://repair2000.com/coupling.html
Here is one I made:
Direct drive coupling replacement by
TheMobilian
May 16, 2009 | Washing Machines
Kitchenaid washer top load will not adjatate or spin
Bad/broken coupler connects the motor to the gearcase.
Mar 07, 2009 | KitchenAid KAWS850LE Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
352 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
