Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
The subject washer is leaking water into the wash tub after the wash cycle is complete. Noticed some clothes are wet at the end of the wash cyle closest to the bootom of the tub. This morning a big puddle on the floor (as the door usually left open when not in use).
Suspect leaky water valve. Question is it coming from the water pump? How do I fix? I am planning to clean the drain pump in any event as I await your response.
Many thanks in advance!
  • Anonymous Dec 15, 2008
    I have the exact same problem. Please someone help.
    Problem Solver:
  • 17 Answers
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Posted on Dec 16, 2008
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water during spin cycle
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Washing Machines
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer Leak
Check the back of the tub as the water is coming in. Sometimes the water inlet gets knocked out of line if the machine shakes a lot or gets moved.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Water standing in tub after cycle has been completed
hi i only fix uk machies but from what you are saying it sounds like the pump may be blocked ,have a look behind the lower panel at the bottem of the machine to see if there is a filter if so try to empty that,hope that helps.
Nov 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
622 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
