Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
When I turn my hitachi plasma tel on I see lots of green dots all over the screen is this an adjustment problem or a part going out
I had the same problem with my Hitachi 42edt41. It was the Y sustain pcb. Large board on the left as you are looking at it from the back. Costs about $750. for the part.
Bill
Posted on Dec 30, 2008
Blue dots on my tv screen
The model indicated is a Plasma set and if blue dots in motion (moving) may be either on the MAIN board (processes all signal) or it is even possible to be a problem on the power supply board.
Most likely a shop repair as someone would have to look, order board/s and actually replace them to find which board is bad.
This is the nature of repairs in all Plasma sets.
Only boards are sold and no individual parts.
Mar 22, 2012 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Pioneer plasma pdp5050hd about 5 yrs old why do green dots pop up in the screen
Your PDP voltages are not set to correct values. They somehow changed and that is the reason you are seeing these dots. Have a qualified tv tech adjust these values. Why ? Because setting incorrect voltages can damage your screen and the voltage controls are located inside the tv. The set holds potentially lethal voltages for several hours after its turned off and unplugged.
Oct 20, 2010 | Televison & Video
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
My TV has little green dots all over the picture.
You have the problem called "diffusion" errors, or some call it non-erasing pixels, etc.. You may be able to adjust the voltages to fix the issue. The 2 main voltages are VS and VA. The value they should be is listed on the back of the plasma panel. If one is off, then it could be the cause. Some manufacturers recommend turning up or down vs or va by 10% to fix this type of issue. Unfortunately, it can also be caused by many board in the tv.. power supply (where vs and va are generated) plus also the y and z drive boards, buffer boards, etc. If they are across the whole screen, suspect the power board and Y board most likely. I can talk you through all the adjustments but you will need a dc voltmeter capable of handling 250v. Let me know your skill level and we can fix this together.
Jan 28, 2009 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Hitachi Plasma - green dots
Please read all the info before you start and if you have any question please feel free to message me at pleasefixitdave@yahoo.com or just give me a call @ Cell # 1-503-432-9904 Ask for Dave! What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers adjusters.b5e4dcb.jpg You do not want to touch any of the adjusters other then the two that has the location #'s VR1 & VR2 next to them. Please make sure you have located the right adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright thin line over the top of the Blue with yellow center adjusters. This will help you put the adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have adjusted the adjuster. At this point you should have the TV with the back cover off and the TV in the up right position with the stand on the TV. Now you will need to find a friend to watch the screen while you make the adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the adjustment. Start the adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the adjuster back in the factory set position and turn the adjuster VR1 clock wise until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2! WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page. Please feel to message me or give me a call if you have any question regarding the repair of your TV! Thank you! 03.gif Dave All TV Repair Cell # 1-503-432-9904 pleasefixitdave@yahoo.com
Aug 05, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
175 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
