By Melissa - usenet poster
My food processor stops dead in mid-chop, i think its the belt - how can fix it?
2 Other Users Have The Same Problem
Comment by Devorah9, posted on Jun 02, 2008
I have a Hamilton Beach Food Processor 70650 and it just stopped, can you help me?
Thanks,
Devorah Merwitz
Comment by Guest, posted on Feb 11, 2008
The handel you psh down just goes down when you put the top on and click into lock is it the belt or somthing else
Best Solution
posted on Aug 08, 2005
Peter1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dealing with a worn or broken belt
1. Unscrew the machine's base, using a screwdriver. You may need to pry off the rubber feet to access some of the screws.
2. Inspect the drive belt (see A). If it is slack, loosen the screws holding the motor assembly (see B), and follow step 4 to increase the belt's tension. If the belt is broken, get a replacement from an appliance store or the manufacturer. (Images 1 to 2)
3. Install the new belt. Loosen the screws holding the motor assembly, and shift the drive gear toward the reduction gear so you can slip the belt over each gear.
4. Shift the drive gear away from the reduction gear to increase the belt's tension, then tighten the motor-assembly screws.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Ultimate Chopper 0.75 Food Processor
Email this problem
Email this problem
This Problem Also Relates To:
Black & Decker MFP100 MiniPro 1.5 Cups Food Processor
Black & Decker MFP200 MiniPro Plus 2 Cups Food Processor
Black & Decker FP1400 Quick N Easy Plus 8 Cups Food Processor
Black & Decker FP1445 Food Processor
Bosch MUM4420 Concept 6 Cups Food Processor
Bosch MUM4620UC Food Processor
Bosch MUM4750UC Food Processor
Can you Help with these Food Processors problems?
glass top [cover] is broken
wher do i get a top to buy Answer This...
Ultimate chopper replacement...
Are replacement parts... Answer This...
Ultimate Chopper - need spare...
Model # C-H1-600 Looking for... Answer This...
CH-1 ultimate chopper
Rubber bushing in blade base is... Answer This...
I received a Cuisinart food
I received a Cuisinart food... Answer This...
Repair Service
Find Food Processor Repairman Near You:
