Question about Dryers
Trying to determine if it is worth replacing the heating element on a 12-15 year old electric dryer?
  • Dryers Master
  • 8,220 Answers
Are you kidding me? Light bulbs don't last for 15 years, why would ya think your dryer heating element would last longer. Me I replace the element every time. Todays newr electronic **** is worthless.
Posted on Dec 15, 2008
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Blowing cold air out.
Sounds like the thermostat is broken, either that or the heating elements has gone.
There's not much else it CAN be, to be honest.
Maybe you just need a new tumble dryer. If you're on a budget don't forget you can get those "small" half size ones remarkably cheaply and they do a good job.
If a tumble dryer's more than a few years old they are seldom worth repairing. Don't let anyone other than a qualified repair man mess about with it, remember they can be a significant fire risk if they go wrong.
It's probably the heating element if it's an electric dryer.
http://www.doityourself.com/stry/how-to-...
please comment on these solution by how helpful.rating or voting.
Dec 24, 2010 | Zanussi TC7102W Electric Dryer
This is a Bosch electric dryer that is 10 years old. The heating element is gone. Is is worth fixing? Or should I buy a new one.
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
Dec 03, 2010 | Bosch Axxis WTA4400 Dryers
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
May 10, 2010 | Asko TL751 Electric Dryer
Not heating
Probably the heater element has failed, it would probably be better to think of replacing the dryer at 10 years old, as Bosch spares are very expensive.
Hope this helps you to make a decision as to what to do.
Jan 04, 2010 | Bosch Dryers
It spins but won't heat
THE ELEMENT NEEDS TO BE REPLACED OR THE WIRES NEED TO BE CHECKED TO MAKE SURE THE CONNECTION IS GOOD
May 29, 2009 | Crosley CDE6000 Electric Dryer
Whirlpool dryer not heating-
HI, To get to the element, you have to remove the lower front panel. You will see the element on the right side under the drum.
With the dryer running, you should have 240V the the two terminals on the element.
If there is voltage, replace the element. If there is no voltage, check the thermastats and the fuse. UNPLUG the dryer and check them for continuity. They should be closed.
This dryer is worth fixing. They are good ones.
I can help you with part #'s or answer more questions if yyou need.
I hope this helps
Vic
May 23, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Dryer problem
hi thanks for the question are you saying that the whole dryer shuts off after 2 minutes or just the heat if your dryer runs for 2 minutes and then cuts out then you wait 10 minutes it goes again then its the motor thanks the appliance doc
Aug 25, 2008 | Kenmore 62872 Electric Dryer
Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Mar 06, 2008 | Dryers
Dryers Logo
Top Dryers Experts
