Question about HP mx705 17" CRT Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
I have an HP mx705 17" CRT monitor that works fine for about 5 to 10 minutes. Then, the vertical sweep goes black for a split second to about halfway up the screen. Within 2 to 3 minutes, half the screen goes black. About 2" from the top, and 7 inches from the bottom leaving me with a crunched picture about 6" tall. It stays this way, even after I turn the monitor off for a few minutes. If I shut down and re-start the computer afterwards, it temporarily fixes itself. Any suggestions? HP was not interested in my problem.
  • Cdon Don Mar 16, 2007
    I switched monitors with an older computer.
    It does the same thing on the other system.
It seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
    Novelist:
    Champion:
  • 202 Answers
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Posted on Mar 15, 2007
SOURCE:
Black screen
The problem could be in the Monitor, Computer or Cable. Did you try to connect another monitor or can you try to connect another computer (maybe a laptop) to that monitor?
It's important to understand where to start.
Thanks
Nov 09, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
My monitor does not display full screen though all the settings are OK. This problem has just emerged recently. The vertical size is fine and the horizontal size is the affected size.REMEMBER ALL THE...
The Horizontal power supply voltage is low. This is provided as a "sawtooth" waveform via the CRT flyback transformer.
Some flybacks offer a voltage adjustment via a potentiometer ("pot") on the side of the unit. I do not have a schematic for your monitor, so I cannot tell you for certain if this is an option. This adjustment should only be made by a trained technician. If you are not familiar with high voltage electronics, DO NOT OPEN THE SET!
I recommend replacing the monitor. When they age, you can only buy some time before it goes for good, and prices are so low now that repairs are not usually cost effective.
Feb 01, 2011 | Daewoo Business 526X (White) 15 in.CRT...
Only Horizontal line in monitor
It looks like the vertical sync controller chip is faulty. Get it repair by certified technician.
Jan 03, 2011 | HP 55 15 in.CRT Conventional Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Bottom third of screen went black
Vertical section problem
change all caps in vertical sec and replace vertical IC
Oct 10, 2008 | Dell UltraScan 1000TX 17 in.CRT...
Vertical distortion
try to replace all capacitor in vertical section a leak capacitor can make your screen to shrink....
Sep 12, 2008 | NEC AccuSync 90 19 in.CRT Conventional...
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
HP mx705 17" CRT Monitor Logo
159 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
