Question about Nintendo DS Lite Console
A NEW NDSL R4 REVOLUTION 3 FOR DS WILL NOT RUN
ALL I GET ON SCREEN IS LOADING AND GOES NO FURTHER
GARYPAINTER2
  • 17 more comments
  • Anonymous Dec 14, 2008
    with my R4 all i get is is a loading screen and it goes no further
  • Anonymous Dec 15, 2008
    The same thing is happening to me.
  • rdbarber Dec 16, 2008
    Brand new DS Lite and new R4 but all I get is loading on the DS screen.
  • iandawson16 Dec 16, 2008
    When new sd card is used in r4 rev 3 for ds, it locks on "loading" but other sd card works and also the new card works in other r4 revolution cards.
  • KarenApps Dec 16, 2008
    Exactly the same problem. Help!
  • alisio Dec 16, 2008
    help I have the same problem but I dont know if I downloaded the games and saved them to the right files. but when i click on E drive it shows the games are there ????????????????
  • pijohn25 Dec 17, 2008
    Yes, I have just purchased the new NDSL R4 and have the same issue, I get as far as loading........ help!!!
  • sambexuk Dec 19, 2008
    all i get is loading.
  • zura09 Dec 19, 2008
    I didn't know that I got the same loading problem until I came across this website.
  • Anonymous Dec 25, 2008
    my DS does not know i have a R4 in. It will not read it
  • gavinkeeley Jan 11, 2009
    i have just bought a new r4 card when i put it in my ds its says "loading" and does nothing else any ideas
  • GabyT Jan 13, 2009
    I just both the R4 but I don´t know what ver is and I´m getting the¨loading¨ screen. I´m using a 2 GB sd. Any ideas!!!!
    Thanks
  • jarvie_nicol Feb 04, 2009
    Just says loading and stays like that.
  • wendymc Feb 13, 2009
    my niece has 2 r4 cards but both of them has just sopped working. i have tried all ways to put new files on etc can anyone help as i would love to fix them for her.
  • pillow13 Feb 14, 2009
    I have the wrong Kernel for my R4 Revolution. I don't know where to find the right kernel. can I have a link?
  • roca379 Feb 22, 2009
    i'm having the same problem with the 8 gig, there seems to be a computability issue with a card that large. it was loading fine before i added more games to it then it stuck on loading. reinstalling original software didnt work, formatting to new kernel didnt work either, i even blew on the contacts. i'm gon try one more time then give up and buy a 4 gig.
    r4 chips do read sdhc, if you get the sdhc r4. there are two types. the original r4 will not read sdhc, you'll get stuck on loading screen.
  • Anonymous Mar 05, 2009
    i have the same i bought 6 r4(1 gig) they work when i tried them util i deleted the sofware for new r4 sofware but it wont work on the apacer ones but worked on the r4 an msd 1s can u send me a link plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  • Anonymous Mar 27, 2009
    i got the same problem too. its stuck on the loading screen and i dont know what to do.
  • 3 Answers
I have a ndsl r4 ver 3
and had it some time,
they are alittle fussy at times,
But go to www.ndslr4.com download v1.25 English
This should solve the problem or at least ease it,
You may have to power on and off a few times, take the R4 out everytime you do this, but once it works it works well, i have over 165 games on one R4.
Posted on Jan 12, 2009
Hi there. You need to ensure you download the correct kernel for the R4 that you are using. R4.com for the standard R4. R4III.com for the R4III and R4Ultra.com for the R4Ultra (with the SDHC memory card). I had the same problem - all I got was loading, but when I found the correct site (after trying them all of course) it works perfectly. Note: The kernels are compressed and you will need to download WinRAR to open them to see the files. Once you have done this copy all the files to the root of the SD card (this just means - don't create a folder to put the files in) and then create a folder called 'Games' to place all your games that you download in. Good Luck.
Posted on Jan 13, 2009
I have been having problems with my new kingston 8 gig micro sdhc on my R4 III card. I was using an Adata 4 gig micro sdhc without any problems for over 6 months. I am using v3.07 firmware on the 4 gig and 8 gig. When I copied the stuff off of the 4 to the 8 I got garbage files listed on the games screen. I have been fighting with 2 8 gig cards with the same problem. The only way I have been able to get the r4 III to load so far is as follows:
1st remove any files that I don't have copies of.
2nd format card
3rd copy firmware to card
4th load up card on ds to make sure it loads
5th load a few (not all, only about 10 or so at a time) nds files and recheck on ds
6th rinse and repeat 5th until done
I hope this helps
Posted on Dec 25, 2008
My initial try was with a 4GB Micro SD card. I found some forums that said the original R4 would not work with a card over 2GB. Today I tried a 256MB card and it worked great.
Posted on Dec 17, 2008
  • 4 Answers
Ive run into these same problems, one solution is to download the latest firmware patch from r4ds.com, i believe they are up to 1.18 right now. the other thing i have noticed is the R4 chip doesnt read the SDHC cards, they just arnt compatible. if neither of those work then pull it out and clean the contacts, maybe even take the R4 apart, it is only 1 screw, and clean the contacts there.
Posted on Feb 17, 2009
Hi make sure that you have put the correct software on the memory card first. Download from here www.memorybits.co.uk/r4
Choose the colour of your catridge and download the correct file.
Un-zip using Winrar (link at the bottom of the page)
copy the contents directly onto the memory card.
Put games directly onto the memory card
Once done put memory card back in the R4 and play on the DS.
Hope this helps.
Dean.
Posted on Dec 20, 2008
    Problem Solver:
  • 6 Answers
How can you have a dsi read a r4 revolution card?
no different software save your games on your pc get new card then transfer the games
Jul 01, 2014 | Nintendo DS Lite
I have a r4 card that I purchased. It has a 2GB micro chip in it with several games already downloaded on it. The R4 card says Revolution for DS (NDSL/NDS) My question is why will it not work on my...
The R4 was Made in 2004 and the production stopped in 2008. And DSi has Firmware that the R4 Will NOT Work with the R4. I advise you to use an R4i or something else.
Nov 08, 2010 | Nintendo DSi Black Console
R4 SDHC Upgrade gives error "MENU?" on startup.
Are you download real programs for R4? Go to www.r4ds.com to download it,it will better because i download it at there too and it can play
Jan 23, 2010 | Video Game Consoles & Games
I have recently purchase a R4 chip for a NDSL and have tried loading games via a disk and by a download. I have confirmed that the files are on the chip but when I try to load them on the handset the unit...
have you installed the R4 system data on the memory card from the R4 website?
If all is well with the data on the card then you may have a connection problem between the sd card and R4 card or R4 card and ds. so investigate the cleanliness of the pins and the tightness of the cards in their sockets.
Some copy DS lites are fussy and don't work well with smart cards. A new motherboard would cure this but it will cost you £50-60
Jan 23, 2010 | Nintendo DSi Black Console
R4 in NDSL freezing
The only thing i can suggest is to go to the site that is on your card and download the new firmware for your card, it maybe that you just need to update your card, if that dont work you may need to buy a new card, i would not leave your card in the nds if you are not using it for a while, take it out, dont leave it in the nds, it maybe that the contacts are worn.
Sep 28, 2009 | Nintendo DS Lite Console
Getting a R4 revolution for DS to play games.
first format your sd card
open the system file and send all the files to your sd card (4 or 5files)then send your games to card...and enjoy...there are tutorials on you tube.
May 01, 2009 | Nintendo DS Lite Console
Freezed on loading screen !!!!!!!!!
Hi, the original R4 revolution will only worked up to kernel 1.16 or 1.17 or 1.18 (cant remember its one of them). Anything that is higher than that are for the R4 SDHC and others (different type). R4 Cards can be pretty confusing as there are many types (original v2, v3, SDHC, supercard...etc) and they all have their own website. Cant remember the link to the original one but you can get the software at http://nds-gear.com/software-r4v2.zip
Hopefully this one should work for you
Feb 02, 2009 | Nintendo DS Lite Console
4G micro SD
i had the same problem, my 2 gb would work ok but not my 4gb i have heard that the 4gb wont work on the older r4's, so i bought a ds Lite R4 Revolution III (Version 3) from amazon.co.uk and it came with evrything you need and it worked great the address is https://www.amazon.co.uk/s/ref=nb_ss_w_h_/275-1618189-4849908?url=search-alias%3Daps&field-keywords=DS+Lite+R4+Revolution+III+%28Version+3%29&x=14&y=15
Nov 03, 2008 | Nintendo DS Lite Console
Couldn't dind ds-menu.dat using R4 card
hi
first of all , check your r4 version.
there are many.
have you put the right firmware on your r4?
original : http://r4ds.cn/download/r4_v1.18_kernel.html
r4 revolution pro : http://www.r4dspro.com/download_en.html
r4 ultra and de luxe : http://www.r4deluxe.com/en/down.asp
r4 III : http://www.r4dsl.net/download-en.asp
after that it should work.
or maybe you should format your memory card first.
Aug 15, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
6,738 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
