Question about Harsper HP-4200VPM Television
Buzzing sound coming from TV
Hello, I recently turned my TV on and noticed that there is a buzzing sound coming from the back of monitor. It sounds like there is a bee in the Television. It is so annoying, I cannot even use the TV. The sound occurs even when the cable is not turned on. Please help me. -Linda
  • phil98 May 10, 2008
    Same problem here.
    Still looking for maintenance center in Europe …
  • nkpearson Nov 09, 2008
    My 40" flat panal panasonic tv makes a constant buzzing sound and I have to turn the volume way up to cover the noise and it still doesn't help completly. It was an expensive tv and I have had it for 6 months. I don't know how to fix the problem.
    Champion:
  • 217 Answers
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Posted on Apr 16, 2007
I just started having the same problem. it comes from a large capacitor changed them but the new ones still make the noise.
Posted on Jul 30, 2009
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung P237HD tv/monitor,unit buzzing when on.
I would take it back unless you have time to investigate the problem before the return policy expires.
If the sound is coming from the speakers then it is interference and would likely happen with another TV.
The interference type can be electromagnetic or radio frequency, both of which can be defeated.
Start with plugging it into a different outlet. If that doesn't work, then unplug anything from it one device at a time to see which thing is the culprit. If it is one of the devices, move any audio cords away from power cords and/or position the device further from the television.
Household appliances and fluorescent lighting also can cause signal interference in electronics that is audible.
A device known to help with such interference are power line conditioners from such brands as Tripp lite, and ferrite clamps. You can place ferrite clamps on the power cords of your devices and their analog audio connectors.
Jan 10, 2010 | Samsung P2370HD 23 in. TV
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Koss KLD2700 LCD TV no picture
http://www.fixya.com/support/t860220-screen_blank
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Televison & Video
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Televison & Video Logo
2,187 people viewed this question
Top Harsper Televison & Video Experts
Are you a Harsper Televison and Video Expert? Answer questions, earn points and help others
