Question about Biostar P4M890-M7 Motherboard
No Sound After Reinstall
Hi
I just upgraded my CPU. Following best practice, I reinstalled Windows once the hardware part was done. Windows installed fine, but now doesn't detect the on-board audio device. If manually selected, Windows cannot start the device.
Specs:
CPU: Intel Core 2 Quad Q6600 @ 2.6 GHz
Mobo: Biostar P4M890-M7 SE
RAM: 3 GB
GPU: nVidia GeForce 7200GS 256MB DDR2
Sound: On-board Realtek Azalia 5.1 High-Def Audio
OS: Windows XP Pro SP3
So Far:
  • I installed all the drivers from the mobo CD
    • VIA 4 in 1 Chipset
    • VIA On Board LAN
    • VIA USB 2.0
  • I've downloaded the latest version of the sound driver from both the Biostar site (WDM_R209) and the Realtek site (WDM_R210)
    • The sound drivers install fine, but then don't run. The Realtek component isn't added to the control panel
    • If I manually add the device (Control Panel > Add Hardware), the Realtek HDA codec appears, but shows "This device cannot start. (Code 10)".
  • I installed the MS HD Audio Class Driver 1.0 (KB835221). No change.
So who's got some ideas about what I can try next?
  • rossj81 Dec 14, 2008
    Thanks for the response, levetate.
    I reset my BIOS after the install using the jumper pin. I then opened the BIOS and loaded the optimised defaults.
    I
    have looked in the BIOS, but can only find one setting that I think
    applies: Integrated Peripherals > VIA OnChip PCI Device > Azalia
    HDA Controller. I have tried both "OFF" and "AUTO" without success.
    I
    Problem Solver:
  • 10 Answers
Have you Reset you BIOS,because after you build a machine up,the Bios has to be set to Default,and were you grounded with a arm band when you put the parts together?,During the assembly it is paramount that you wear a grounded arm band so that your body electrical discharge does not interfere with the components,you probably have a hardware/software conflict.some thing in the BIOS is most likely left on.or set to hardware.
Posted on Dec 14, 2008
How do i Reinstall my sound?
If you have the CD, reinstall the drivers using the CD that came with the hardware. If you don't have the CD, then you're going to have to visit the hardware manufacturer's website. Follow the link that usually is labeled "SUPPORT". Find your exact equipment using the model number. They usually ask you to select the Operating System, such as Windows XP, Vista or Windows 7/8. Select your operating system and click on the link that appears. Once downloaded click on the file and this should jump start the install process. You probably need to reboot once that has completed and viola... your sound should work once again.
Jan 02, 2014 | Dell OptiPlex GX620 PC Desktop
I have problems white my DVD-RAM GH40L I got Code 32 every thime, what shall i do Facts HL-DT-ST DVD RAM GH40L ATA Device and version 6.0.6002.18005 Windows Vista
Hi manus138785
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
Best regards
fanaudi
Aug 12, 2011 | HP Computers & Internet
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
I've recently installed a new Gigabyte G31 motherboard. It boots and even reaches the to the windows initial loading logo but then shuts down. I tried to look at system diagnostics in the CMOS setup and...
Hello, if you change/upgrade your motherboard then you will most certainly have to reinstall windows from scratch...treat it as a new system. Don't forget you will also have to install the chipset drivers that came on the cd supplied with the mb., as well as all the other drivers for network card, audio, and graphics if they're not embedded in the mb.
Regards,
nicam49
Dec 11, 2010 | Computers & Internet
Ihave ax4650 wirelellprinter.it worked under
You need to uninstall the printer completely from Windows 7 and download the driver from the following link. http://bit.ly/5sKzoy Once you have downloaded the driver follow the on screen installation instructions to reinstall your printer using the correct driver.
Jan 19, 2010 | Lexmark X4650 InkJet Printer
I have just reinstalled windows on my pc and the resolution isn't the same. The image is too large. I have been told I need to download something from dell so my cpu will recognise my monitor, what do I...
Since you have reinstalled your Operating system you will need to reinstall the Drivers for your Video card, sound card, Modem and other hardwares. You need to install drivers for each and every hardware in your computer. Windows has inbuilt drivers for most of the common hardwares like mouse keyboard modem etc. but for some specific hardwares like Sound card Graphic card, Network card etc. for which Windows cannot load the drivers on its own, we have to install them.
Driver is a set of program which helps your hardware to communicate with the Operating system (e.g: Windows).
For your Dell Monitor E153FP you can download the required drivers from the following site:
http://support.dell.com/support/downloads/download.aspx?releaseid=R76072&formatcnt=1&libid=0&fileid=99367
Hope this information is helpful to you.
Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya
Dec 03, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
Wish to increase cpu spped and memory
Hi thefuncouple, here is the ASRock link for supported CPU's:
http://www.asrock.com/mb/cpu.asp?Model=K7VM2&s=462
The Athlon XP 2600+ CPU is the highest CPU this board can support. (It will be hard to find one).
Main web site for the K7VM2: http://www.asrock.com/mb/download.asp?Model=K7VM2
Honestly, ASRock does not have drivers for Vista. Some of the drivers listed for XP may work with Vista. Your best chance is to download & run Windows Vista Upgrade Advisor 1.0
(Before installing Vista in to your system).
http://www.microsoft.com/downloads/details.aspx?FamilyID=42b5ac83-c24f-4863-a389-3ffc194924f8&DisplayLang=en
Vista, any version needs at least 1GB of memory. Two GB is recommended. After running Upgrade Advisor you will know if your ASRock motherboard can handle Vista. You should be able to upgrade to Vista (Over-writing XP) but only if your system passes the Upgrade Advisor.
Your best bet would be to buy a new system with Vista on it. Your ASRock board is just too old for Vista. You'll save money upgrading to a more supportive PC.
Good luck thefuncouple!
Vista is not for everyone, many users end up going back to XP.
Thank you for using fixya.
Mike
Dec 11, 2008 | Asrock K7VM2 Motherboard
Prosser runing at 100 persent
mcannirwin
In regards to your question about upgrading your system mainly if you change out the main hardware you will need to reinstall your operating system, I will assume that you have Windows. However his does not mean you will lose your data.
Normally if you have to replace the motherboard on your system unless it is the same model board you will need to reinstall Windows. Now with the CPU upgrade you may not have to depending on the differences between the new and old CPU but it is a good idea to do any ways. The reason for the is that when Windows is first installed on the system it scans the system to see what hardware is there then installs the right drives needed to run the system properly.
Another way to look at is a human we all have the same parts. However I can not just give you one of my kidneys if you needed it. You have to make sure that it is compatible with your system. The same thing is true with computers. So that is why you will need to reinstall Windows. Note you should be able to change out the other hardware with out any trouble, except the HD of course because it has your operating system on it.
Now comes to the part with your data. There is a couple of ways you can does this. Ether you can back of the data to CD or DVD. If your have a 2nd harddrive you can move the data over to it then format the first one to reinstall your Windows on. The easiest option is if you do not have another harddrive or want to add another one is to buy a new one. Then you can make this the drive that you reinstall Windows on and keep all you other data on the other drive.
Hope this helps
If you have any more problems and/or questions let me know.
Issken
Oct 02, 2008 | ASUS A7V400-MX Motherboard
Blu-ray problems from blu-ray computer drive.
Vista takes significantly more procesing power from your CPU than XP did. The colored squares, or pixellation, are a result of your computer's processor having a bit of trouble keeping up with the demands of the Blu Ray video. To resolve this, you can do several things: Upgrade your CPU(You can upgrade the the highest CPU your current motherboard will allow) Upgrade your RAM, (RAM is fairly cheap for the bang you get and will be the cheapest upgrade option.) Max it out if you can. Reinstall XP back on your computer. (Cheapest option, period). This time, use Ghost or some other imaging program to image your Hard Drive once you get it working correctly so that you can recover in minutes as opposed to reformat-reinstall next time.
Jul 10, 2008 | Computers & Internet
Biostar P4M890-M7 Motherboard Logo
413 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
