Hello. My dishwasher starts by pumping out water then it lets water in and when it starts to sprinkle it stops then tries to sprinkle again and stops and so on. I opened front panel and shorted door switch and started a program. I see that sprinklers work throwing water like 15 cm in air and then stops and starts again and again.
SOURCE: Candy Dishwasher CS455M
i have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
SOURCE: candy nova cd112 dishwasher fills with water then stops working
Sounds like the main pipe is clogged - or the food filter. Check that the filter is completely clear.
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
SOURCE: I have a Candy dishwasher. Door is open switch on
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
SOURCE: Candy Dfi 85s intergrated dishwasher
candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
