Question about Samsung Digimax S800 Digital Camera
Put new batteries in, camera bleeps three times & switches off
Hi there I put fully charged batteries in, and the screen comes up for a second, enough to see the abttery strength is full.
The camera then beeps three times and switched back off.
The lens has not fully went back into position either.
    Scholar:
  • 83 Answers
Hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Posted on Dec 14, 2008
Casio Exilim won't turn on
My guess, only support people know what the two beeps mean.
Try to remove the battery and after a few seconds insert it again.
Then again switch on. If the error returns, contact the dealer or Casio support. Still it could be you think the battery is charged, but the capacity is not enough to power up your camera.
Dec 31, 2013 | Casio EXILIM EX-ZS10 Digital Camera
Camera won't turn on with fully charged batteries in it.
try cleaning the battery contacts. At certain instances it may be necessary to scrape them or to partially bend them that they provide a bit more pressure towards the battery terminals.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Canon PowerShot A95 Digital Camera
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
My camera starts to switch on bleeps and then closes down, any ideas please?
Hi. Check the battery if it has enough charge to power on the camera. Hope this helps.
Feb 03, 2011 | Pentax Optio S7 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
After being reset and plugged back into computer to charge, a red light pops on as soon as plugged back into usb port to charge and will not turn on.
Put a pin in the reset button situated in the tripod hole.Do it three times for about thirty seconds each time.Also depress the on off switch for about thirty seconds.Put it in the usb port of your computer to charge.After about thirty minutes or an hour the screen should go white.A battery shows on the screen.Wait till the battery shows all green,then it is fully charged.
Oct 28, 2010 | Pure Digital Flip Mino Digital Camera
The battery is new and fully charged, and when i turn it on it comes on for about a second before goes totally black and switching off. It does this before the lens has a chance to come out.
it may be the batteries. if you buy really cheap ones EX sunbeam ,or ac delco .the cheap batteries do not put out enough voltage for your camera to function . i suggest trying a couple of duracells
Aug 07, 2009 | Cameras
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
Camera refuses to switch on, makes bleeping sound and cuts off.
this might be indicative of a weak battery.
In some instances even if the battery is new or fully charge, the same symptoms would be exhibited. If this is the case, it is probable that the battery contacts needs a bit of cleaning/scraping. Additionally, it may require slightly bending the said camera's battery contacts to ensuire a bit more pressure towards the battery.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Cameras
Not charging
same thing happened to me and I've found 2 solutions:
1. Casio has recognized that this is a problem with the battery. If you call the support line and tell them the problem, they will send you a new battery for free. All you need is the serial code on the bottom of your battery.
2. This sounds crazy but it worked for me. Take a 9v battery and touch the connectors to the connectors of your np 20 casio battery. make sure to touch + to + and - to -. hold it there for 30 -60 seconds. put the np 20 back in the camera and put the camera on the dock. this will give it just enough charge that the charger will recognize the battery and start charging your camera to full.
Mar 17, 2008 | Casio Exilim EX-S600 Digital Camera
Samsung Digimax S800 Digital Camera Logo
119 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
