Question about Harley Davidson Road Tech HA90 MP3 Player
Need illustrated instructions for mounting '08 HD police seat
Have '08 police bike that the dealer placed 2up seat instead of retaining police solo seat. Just purchased seat and mechanism from dealer who recently removed it from an '08 bike for commercial sale. would like detailed illustrative directions for installation
  • 91 Answers
Seat uses holes allready there in fender the pressure tank mounts in the saddle bag holes need to be drilled realy simple install please give me a rate helped about 20 people and only have 5 ratings hope this helps
Posted on Jan 03, 2009
Want to put a solo seat on a 1994 Honda CB 250 Nighthawk
Hi, 99percentrig the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Other Seating Parts for Honda Nighthawk 250 eBay
Want to put solo seat on 1994 Honda CB250 Nighthawk Google Search
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Feb 12, 2013 | 1994 Honda CB 250 Nighthawk
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
How do you remove the starter on a 03 Harley Davidson Dyna Low Rider?
Instructions
  1. Removal
    • 1 Remove the seat retainer screw from the seat mounting bracket using a ratchet and Allen driver. Lift the rear of the seat up and slide the seat toward the rear of the bike to disengage the seat from the frame and remove it from the bike.
    • 2 Don a face shield and rubber gloves.
    • 3 Remove the battery cover retaining screw from the bottom of the battery cover using a ratchet and Allen driver. Tilt the top of the battery cover out and lift the cover to disengage it from the battery tray.
    • 4 Remove the negative battery cable from the battery using a 10 mm wrench.
    • 5 Remove the positive battery cable from the battery using a 10 mm wrench.
    • 6 Unhook and remove the battery strap. Remove the battery from the tray. Remove face shield and rubber gloves.
    • 7 Remove the two top battery tray screws from the frame above the battery tray and the bottom battery tray screw from the inside of the battery tray using a ratchet and Allen driver.
    • 8 Remove the battery tray from the bike while guiding the battery cables through the holes in the battery tray.
    • 9 Remove the starter end-cover nut, using a ratchet and socket, and pull the end-cover off the starter.
    • 10 Pull back the protective rubber boot off the positive cable terminal. Using a wrench, remove the positive cable nut and then lift the ring terminal off the starter terminal stud. Unplug the solenoid electrical connector from the solenoid.
    • 11 Remove the two starter retaining bolts from the starter using a ratchet and Allen driver. Pull the starter off the bike. Remove and discard the starter housing O-ring.
    Installation
    • 12 Inspect the two split-ring bushings in the inner primary case where the starter mounts for slack or looseness. Remove the split-ring bushings and spread them to provide a slight interference fit in the primary housing. Push the split-ring bearings back into position.
    • 13 Install a new starter housing O-ring on the starter assembly. Install the starter assembly on the bike.
    • 14 Apply one drop of Loctite Threadlocker 243 to the treads of the starter retaining bolts. Install the starter retaining bolts and washers and tighten them to 24 to 27 foot-pounds using a foot-pound torque wrench and Allen driver.
    • 15 Install the positive cable ring terminal and nut on the starter terminal stud. Tighten the nut to 65 to 85 inch-pounds using an inch-pound torque wrench and socket. Push the protective boot securely over the positive cable terminal. Plug the solenoid electrical connector into the solenoid.
    • 16 Position the starter end-cover on the starter and install the nut, using a ratchet and socket.
    • 17 Place the battery tray in position while guiding the battery cables through the holes in the tray.
    • 18 Install the upper and lower battery tray screws and washers. Tighten the screws to 96 to 120 inch-pounds, using an inch-pound torque wrench and Allen driver.
    • 19 Guide the battery cables into the recesses at the upper corners of the battery tray.
    • 20 Don face shield and rubber gloves.
    • 21 Place the battery in the battery tray with the terminals facing out. Snap the battery strap in position.
    • 22 Install the positive battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds using an inch-pound torque wrench and socket.
    • 23 Install the negative battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds, using an inch-pound torque wrench and socket.
    • 24 Remove the face shield and rubber gloves.
    • 25 Apply a light coat of corrosion retardant grease or petroleum jelly to the terminals.
    • 26 Install the battery cover and screw. Tighten the screw securely using a ratchet and Allen driver.
    • 27 Place the seat on the bike. Lift the rear of the seat and slide it forward to engage the seat tab in the frame slot. Lower the rear of the seat and install the seat retainer screw through the seat mounting bracket. Tighten the seat retainer screw securely using a ratchet and Allen driver. Lift up on the seat to make certain that it is mounted securely on the bike.
Jul 08, 2012 | 2003 Harley Davidson FXDL Dyna Low Rider
How to remove starter from 2008 dyna lox rider . I have already un bolted it and removed wires but it is loose but will not come out yet .
Instructions
  1. Removal
    Installation
Nov 18, 2011 | 2008 Harley Davidson FXDL Dyna Low Rider
How to install a solo seat on a vintage harley davidson motorcycle
On most vintage bikes, the seat is supported by a "T-bar" that connects to the frame between the fuel tanks on the front end and is supported by the spring seat post in the rear. Most of the solo saddles were designed to bolt to the "T-bar". Simply remove the "buddy seat" and bolt on the solo.
Now there are some conversion kits made that eliminate the spring seat post and bolt the saddle directly to the frame. Others have coil springs in the rear. These are better if mounting a solo on a rigid frame machine.
Good Luck
steve
Jul 29, 2010 | Harley Davidson FXDL Dyna Low Rider...
Install auxiliary running light and directional indicator mirrors
Jim as a mech at the HD place he cant modify it,but you can.Bench test the part then meter the circuit on the bike you will have it in no time.
Apr 25, 2010 | 2006 Harley Davidson FXDBI Street Bob
07 Street Bob. At 9000 miles, the engine mounts are loose. Bike shakes badly at low RPMs. Is this common?
You have a torn engine mount, if your bike is still under warranty get it to your dealer asap!!!!! The same thing happened to my 08 Superglide, the dealer was quick to fix it as I had no idea as to why my bike was shaking so badly. Also check that your tank mounts are tight too..
Aug 29, 2009 | 2006 Harley Davidson FXDBI Street Bob
Installation of police solo air ride seat
not to be funny or anything but all i can suggest is have a look see if everything lines up so it can be bolted on
Jan 28, 2009 | 2001 Harley Davidson FLHT Electra Glide...
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
244 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
