Question about Canon PowerShot S2 IS Digital Camera
"change batteries" signal comes in display.
This message appears after new batteries inserted. Occasionally I get about 10 photos and then the message appears. Have swapped batteries around, cleaned and checked battery contacts, in camera and on batteries. Have used new alkaline and rechargable batteroes, all to no avail. Camera is 3 years old and worked perfectly for 18 months, then intermittently,now hardly at all.
  • 4 more comments
  • NaviLani Feb 13, 2009
    I basically have had the same problem. Had it for 3 years and I put new batteries in and it still says it's dead. Help?
  • Anonymous Feb 24, 2009
    I have the very same problem as decribed by jeanlefur
  • donlee971 Feb 27, 2009
    same problem....but for the rechargeable batteries only it works fine with the regular battery... Those rechargeable batteries that had problem with this camera work greate with other camera so I think Canon S2 doesn't like rechargeable bettery????
  • zoomare Feb 28, 2009
    Camera sometimes doesn't recognize new batteries and seems worse with rechargables. Also has gotten worse in last few months, but may be related to cold weather, too.
  • rothjw Feb 28, 2009
    I too have the exact smae problem the camera worked perfect in the beginning now the change battery light is constant
  • Anonymous Apr 07, 2009
    My camera no longer likes rechargeables. I just got brand new Sony rechargeables that were very highly rated on Amazon.com thinking my old rechargeables were 'tired'...took like 4 pictures and then the camera said I needed to change them! Alkalines seem to work fine.
Use alkaline or rechargeable batteries
Posted on Feb 23, 2009
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
C4280 photosmart printer - printer screen says "Printer cartridge missing or not detected" - I replaced the old HP cartridge that was in when the message appeared with a new HP printer cartridge in but it...
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Apr 01, 2010 | HP Photosmart C4280 All-in-One InkJet...
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Error
    The manual states
    1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
    You will have 5 uninterrupted attempts to insert the correct CD.
    2. After the 5th incorrect attempt, the display reads (HELP)
    3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
    4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
    IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
    Jul 19, 2008 | Eclipse CD3422 CD Player
    Message that cartridge is empty, insert a new cartridge.
    Hi-
    so you mean thats the replacement cartridge and after printing 10 prints it is now saying you have to change it, chances are that is a defective ink cartridge, you should get more prints from that replacement, here's what, call epson technical support at 562-276-1300 and have your proof of purchase ready and complain on this, they will send you a replacement, i mean they should. now if its going to happen on the replacement ink cart, that after 10 prints and it will say its empty then thats an issue with the printer already. update me regarding on it, but for now my best advice is to call epson. Have a nice day!!
    May 12, 2008 | Epson PictureMate (C11C556001) InkJet...
    Maxxum 7 (analog) - won't turn on
    Apperture base plate set needs replacing or there is a short in the camera ( camera dropped or acid leak ? ) . Especially the first broblem can be sorted only by trained people with some experience.
    May 06, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
    Canon PowerShot S2 IS Digital Camera Logo
    158 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
