Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How do you hook up a dvr to a mitsubishi dlp hd tv?
No output on back of tv.
  • 179 Answers
In the back of the set, on the upper right side of the terminal board
there are 2 jacks. one red one white. just below these are the monitor out jacks (red,white, yellow) it only outputs 480i
Posted on Dec 18, 2008
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
I have a Mitsubishi DLP model # ws-65517, and the HDMI signal is scrambled purple, black an green lines. This is the case with my DVR and PS3, i tryed 2 different HD cables, reset button, unplugging it...
Don't you have more than one HDMI input on the back of your TV? If so, use another input and then select that input with your remote. If not, you may have to do the input replacement which you describe.
Jul 28, 2017 | Mitsubishi Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
Cannot get wii hooked up to our new tv HD
try changing cables use diffrent input output don't
forget to set dvr on right setting , AV, L1 ect
have you got manual , if you are realy desperate to fix this you can call 0403960527 jeff
Feb 16, 2009 | Sanyo DS31590 31" TV
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Hd dvr
if you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Jan 29, 2008 | JVC AV-36320 36" TV
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
