Question about Citizen Aqualand Duplex JP1074-58E Wrist Watch
Citizen Aqualand Duplex locked up......
My watch has locked up. The analog portion has stopped working and the digital portion seems to be frozen in time. I tried the reset function in the manual, but that didn't fix the problem (made no change). Could a low battery do this? The watch has been in this state for about 6 months now. Thanks, Brian Johnson
  • K100wigg Nov 30, 2008
    Exactly as above.
    Analogue awas stepping like low battery warning. Fitted new battery and all was locked up, including digital display.
    Put old batter back in, I thouht after waiting for the volages ti fade but now ALL locked digital and analogue!
5 Suggested Answers
SOURCE:
  • 73 Answers
SOURCE: Instruction manual
Go to this link and follow instructions for finding your particular watch movement and then lookup instructions.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
  • 19 Answers
SOURCE: I have an aqualand duplex and the protective glass is
HI
So is the glass cracked? or do you have an watch protector on it which is broken (usually a rubbery type protector which slips on over the glass)?
Kind Regards
Shenlun
Posted on Jul 12, 2009
escapement
  • 2338 Answers
SOURCE: I have a Citizen Aqualand Promaster 200M circa
First of all they should be giving you explanation why the watch needs whole movement replacement and what is the cause.
As the watch movements are upgraded and made more sophisticated every year, some of them are discontinued and the next generation movements are replacing them. Watch manufacturing companies usually try to produce interchangeable movements, so, the newer one can replace the older.
In your case (if there is no newer version replacement) you have no option, but to shop around for exact new movement for replacement.
All you have to do is to find out your watch's movement number (that Citizen facility in CA should give that) and then shop for it. Plenty of movemevts on ebay, not to mention specialized watch part supplier companies. All available over the internet - just takes some time and nerve.
Rate, please.
Posted on Jul 23, 2009
SOURCE: My citizen aqualand duplex watch has the word
It turns to "chek" if the moisture sensor that triggers dive mode when you go in the water is exposed to water and you don't dive for more than an hour. The sensor is very easily triggered by sweat, so all you got to do is wipe the sensor between the crown and the upper right button with dry cloth and "chek" will go away.
Posted on Jun 08, 2011
Tutorial on battery change
These Aqualand watches have three separate batteries and are not meant to be changed by anyone but citizen repair person. It is best to send back to ensure it is water proof. It's not real cheap though
Sep 28, 2013 | Citizen Aqualand Duplex JP1074-58E Wrist...
Battery replace for Citizen Cyber Aqualand NX
My Cyber was working fine and reporting a full charge, but when diving, it would stop working and go into safe mode. I sent it in to Citizen and they replaced the cell, now all is good again.
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
Battery number for citizen divers watch c506
I just opened my Aqualand Duplex Titanium C506 and the battery is one CR2016.
Sep 08, 2012 | Citizen Aqualand Duplex JP104009E Wrist...
JP1040-09E NON ecodrive (has Battery) digital display froze on same time and hands froze as well now second hand jumps in 2 seconds
The jumping second had is a typical method of telling the user that the battery needs replacing, which would also explain why the hands have stopped.
May 07, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
My citizen aqualand duplex watch has the word "chek" on the lower screen and it won't go away. What does this mean?
Feb 21, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
HI
Kind Regards
Shenlun
Jul 12, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Citzen Aqualand 1997 Divers watch..Great condition!!
the alarm works by a spring rubing on the back of the base plate of the watch if this spring is bent or not in the right place the alarm will not work
Nov 02, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Can't set the hour on my Aqualand Duplex
i followed the instructions on the Citizen website for a system reset and it worked. Unfortunately, the regular way of setting the digital hour does not. Maybe a technical problem? The movement number for the Aqualand duplex is C506.
1. unscrew the analog adjustment crown and pull one click
2. press and hold the other 3 buttons for 3 seconds and release.
3. push the analog crown back and adjust the digital time.
this is a system reset so you will have to set the date. You will lose your settings and your dives. good luck.
Mar 10, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Instruction manual
Dec 05, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
Problem
Just bought an aqualand, and it seems it gives you the word check if you put it in dive mode and dont go in the water for 1 hour. My problem is similar, it goes into dive mode, and I cant abort it. So I just leave it untill it says check, and eventually it disapears and returns to normal.
Oct 19, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
Citizen Aqualand Duplex JP1074-58E Wrist Watch Logo
75 people viewed this question
Top Citizen Watches Experts
Arturs Kalnins
Arturs Kalnins
Felipe Valera...
Level 1 Expert
Are you a Citizen Watch Expert? Answer questions, earn points and help others
