Ye Data Internal Floppy Drive
Problem for Ye Data (YD8V07) Internal Floppy Drive
Does anyone remmember how to Copy floppy to floppy with dos?
By Bray - usenet poster
does anyone remmember how to Copy floppy to floppy with dos?
Best Solution
posted on Mar 09, 2008
Very Helpful)
mahalko_21
Rank: Apprentice
Rating: 100%, 1 votes
computer innovation on hardware system floppy disk to flashdrive
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Very Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Use the MS-DOS diskcopy command by following the below steps:
diskcopy a:
Once you have typed the above command and pressed enter, you should be asked for the source diskette. When it has been entered and the information has been copied, it will then ask for a destination which will be the diskette you want to copy the information to. This process may be repeated several times.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 28, 2008
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
at command prompt type diskcopy a: a:
Solution #4
posted on Sep 21, 2008
Not Rated)
cobalt32
Rank: Apprentice
Rating: 0%, 0 votes
This is a simple way no for Disc Copy from the C:/ use Upper Case as Shown Below from the C:/ Prompt type in the following
A COPY A*.*A HIT RETURN A ssuming all the info will fit on the second Floppy your Good to as Go
This is known as a Wild Card goog luck Peter
cobalt32@eircom.new
Was this helpful?
Yes
No
Solution #5
posted on Aug 02, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Install the floppy that contains the file or folder you want copied.
Click : Send to => compressed file/desktop/or drive (D)?
Best is to send it to your hard drive somewhere ,even (C)
Remove the floppy that you used to copy from.
Seek out the file on (C) drive ( I usually use "my pictures" folder)
Then just use the drop down menu on that file to send it to floppy.
Once you confirm it exists in (C) and is complete , use the drop down menu to select : Send to - again , then send it to (A) or (B) floppy (which will need a fomatted floppy to copy onto).
I do it all the time. Even use that method to send email pictures and alike.
Solution #6
posted on Dec 31, 2007
Not Rated)
harbour9
Rank: Apprentice
Rating: 0%, 0 votes
Have forgotten how to use MS-DOS. And where is "diskcopy a"?
Was this helpful?
Yes
No
Solution #7
posted on Aug 29, 2007
Not Rated)
ENW1
Rank: Apprentice
Rating: 0%, 0 votes
Assuming you wish to make a duplicate of the source disk, the above will work fine.
Be sure to fully format the target diskette(s) before using diskcopy, even if they appear to be empty.
Diskcopy will make an exact copy of the source onto the target WITHOUT testing the target diskette's surface for errors.
If the target diskette has a bad area (or more) on its surface, diskcopy will write data to the bad area(s) and you will not have a good copy.
The full format command will test the diskette surface and mark those bad areas as unusable.
However, this will not fix the diskcopy problem.
Diskcopy would still try to write data to those corrupted areas, it just means you should not use a diskette that has errors on the surface with diskcopy.
Was this helpful?
Yes
No
Popular Solutions for Ye Data Internal Floppy Drive
Questions and Unsolved Problems for Ye Data Internal Floppy Drive
Do you recommend Ye Data (YD8V07) Internal Floppy Drive?
Answer
Answer
how do i turn on and off ceartin midi channels in the motif,so when i have it midi up to another key... (More)
Answer
I have installed it (poor instructions) but what can I do wrong? The cable from the mother board... (More)
Answer
yd 1501c , YE data floppy drive(3.5 inch 720 kb 2 DD) is not working ,kindly help me to solve my... (More)
Answer
i am having ye data floppy drive YD 1501 C , 3.5 INCH 720 DD FLOPPY DRIVE . THIS DRIVE IS NOT... (More)
Answer
mazak microsystem with a ye data floppy. need to replace floppy.info on drive is:pn 134526-41 rev... (More)
Describe your Floppy Drives problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Floppy Drive Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
