Question about Microsoft Xbox 360 Console
My disc wont spin in my drive
When i put my disc in my xbox 360 it reads for about 3 secs and then says open tray and when you listen you can hear that it does not spin at all and it does it with all my games ! PLEASE HELP !
  • Adam360 Dec 14, 2008
    Anything that resolves me not opening my xbox
    Problem Solver:
  • 7 Answers
Hi i have had and fixed this problem pemenently!!
u need to take apart your xbox and remove the dvd drive:
then you need to crack open the dvd drive
once open if you look at the top part of the drive that would hold your game/disc youl notice that it is infact two pieces that are magnetinc and they will be stuck together
what you need to do is seperate them
then take the smaller piece and locate where it has come from
this is the centre on the dvd drive like on the pc where you would push the game on to
you need to super glue the small piece back into positon
reassemble let dry and it will now be working..
i no its hard to understanmd what ive written hear but this is a really easy fix...
Posted on Dec 14, 2008
Xbox 360 tray will work but wont read any discs .discs are spinning but wont play keeps comming open tray
Ok 90% of the time your console gives you the open tray icon when it tries spinning clean disks is because the laser has gotten to weak to read them. Your options are buy a new dvd drive or pot tweaking the laser which is relatively easy if you are not afraid to go hands on with electronics.
here is a good video on the tools you will need to open your xbox http://www.youtube.com/watch?v=Dtm7V4NotgA
Now first i would try cleaning it http://www.youtube.com/watch?v=Dtm7V4NotgA
if that doesnt work I would recommend pot tweaking and here is a tutorial for that http://www.se7ensins.com/forums/topic/93454-how-to-pot-tweak-xbox-360-dvd-drives/
honestly if you do not know much about electronics I would recommend just buying a new xbox dvd drive for like 20 bux off of ebay. But you will still have to open the xbox to figure out what drive you have and to actually swap it
Jul 25, 2011 | Microsoft Xbox 360 Console
My xbox 360 is not playing the games nd it didn't have no ring of death at all whats wrong with my xbox 360
Listen to the console carefully...if it sounds like the disc is being read and spinning then the lens could be dirty. If the disc does not spin it could be two things, one of which I have experienced and repaired. 1: the disc motor could be dead, or 2: the lens cradle is stuck somewhere on the track (I had this one).
If the cradle is stuck then it will make a barely audible clicking sound. To fix this I dismantled my box and the disc drive (WARNING: It voids the 3 year warranty!!!) and pushed the cradle to the center of the tray. Afterward, I opened and closed the tray to see visibly if the laser got stuck again...it didn't. I put a disc in and it read perfectly. So I pieced it all back together in hopes that I was successful. I did it at work earlier so I don't know the end outcome. So far it sounds perfect, disc and all.
Hope I helped =J
Your friendly soldier,
SPC Gaither
Dec 23, 2010 | Microsoft Xbox 360 Console
Will not read any disc's
Its because the dvd scanner is scratched or broken
Oct 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Oct 02, 2009 | Microsoft Xbox 360 Console
My Xbox 360 Halo 3 edition hardly reads any disc successfully!
This most likley a weak laser .
8 mw 633 nm laser diodes fail in stages
as they get weaker the cd ups voltage
to the laser diode till you get to full gain, affter that
it's time for a new laser .Good news
there cheap 30.00-40.00 and not too
hard to swap out yourself .
Rob
Jun 13, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
My 360 wont ******* play
i had the same problem. listen to your xbox cd rom and if you hear it start up and kinda skip or make a weird stopping sound then your disc drive/ cd-rom is wearing out. either send it in or do what i did and start by just giving the center to the center left above your cd-rom a nice few taps in a row while its spinning before it stops. fairly good knocks on the case will help it. i ended up really hittin mine a lot of time in row after about a month. sometimes it will put rings on your games thought but they buff out. i even took it apart but theres not much you can do
Feb 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
223 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
