Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
My fridge freezer defrosted n now wont wrk
My fridge freezer has just stop workin after it defrosted i left it of 24 hours turned it bk on dis morning and nothing it wont freeze or go cold n keep makin a poppin noise...
do i need a new fridge frezzer or it it repairbly
  • emmalarkins1 Dec 14, 2008
    oh its a beko fridge freezer b the way
  • marton65 Apr 02, 2009
    I just moved into a flat that has been empty a few weeks. The Beko stand alone freezer - that I was told was only a couple of years old - was left empty and defrosted. When I turned it on by the little button on the front the button lights up but the freezer is not freezing or even getting cold.
    Can you give me any advice please?
    Jill
  • 71 Answers
What you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Posted on Dec 14, 2008
Fridge freezer stoping after 24 hrs
most of these freezers have an automatic defrost cycle.
after so many hours of chilling it will stop and run a de-icing cycle.
this is accomplished by one or two heating elements.
if one of the elements is burned out it will not run the defrost cycle.
and will ice up quickly.
depending on the model the heaters will usually cost about 15 to 20 dollars and they are easy to replace.
look up the model of your freezer and download the pdf files they will usually have a pictorial diagram showing the location
a defrost timer usually does nt fail on them unless it is physically damaged.
Aug 31, 2013 | Freezers
The freezer cools half way top, below is warm.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
We have bought a new american style fridge/freezer and it was delivered yesterday. We have left it on for 24 hours and the temperature is not going down the fridge wont go below 12 degrees and the freezer...
ambient temp 10/35 degrees C.not in direct sunlight,
did you use a level to make sure that it is level in all planes,just to make sure all the door seals are tight,
(look along the seals to make sure)the unit should be left on for at least 24 hours in its chosen position with the doors shut,then check temp,it could take another 12 hours to settle down once loaded.Also make sure that its not touching the wall cuts down on vibration.
once checked,if still not right call samsung..they are good.
Apr 04, 2010 | Freezers
My whirlpool ART 900G fridge freeser, the freezer works but the fridge wont chill
Check the fan that moves the air from the freezer side to the refrigerator side. It is either stuck in ice or not working. Defrost the refrigerator for 24 hours and then restart it Listen for the fan operation be aware that the fan may shut off when you open the door, so listen closely. Defrosting it may fix or the fan may need to be replaced.
Nov 12, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
266 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
