Question about Nortel 7230 Wireless Bridge
I have forgot the IP of the Nortel 7230 Wireless Bridge. How can I make it factory default mode. Can any guy help me ?
5 Suggested Answers
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
  • 53 Answers
SOURCE: Can't get an IP address over time.
Ok I have guessed a couple of things. Here goes.
the version of software 12.4 (3g) is very old
I think that you have DHCP configured on the AP
the cisco site lists loads of issues regarding DHCP and memory leaks in numerous guises with not only your IOS version but newer versions too.
the reason why I have homed in on this is that you say that the unit works for about a week then essentially stops until you reboot the AP. (I guess that you do this by power cycling not by issuing the reload command) in the short term you have fixed the problem.
I would suggest that you upgrade the IOS to something newer. the current version listed is 12.4(22)T if it's of any help.
lastly as you know when the system actually goes wrong. You are able to issue the reload command with additional settings so it could reload @ X date and time if NTP is configured or you can specify a time duration in minutes if preferred.
I can't think of anything else I afraid.
Posted on Nov 06, 2008
SOURCE: default use name and password with ip address of
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Mar 16, 2010
puertobori
  • 7725 Answers
SOURCE: how do I resolve "authentication error" due to
Go here ->Manual or contact them.Also i read that Nortel is discontinuing availability of the Wireless Bridge 7230 product line. This action is due to a lack in market demand and business justification to continue investment in the portfolio.
Posted on Sep 23, 2011
SOURCE: I want to factory reset
AP7220 has a CLI. To access the CLI you Telnet to the IP Address of the AP7220.
If the AP7220 has a default config, the default IP address is 192.16810.2.
To configure a AP7220 with default config connect your PC to the AP with a crossover cable, and set the PC IP address to 192.168.10.1.
Telnet to the AP and enter the userid and password for the AP (default is admin/admin).
Enter "?" at the CLI prompt for a list of commands. Should be a reset command there.
Posted on Nov 29, 2011
How do I resolve "authentication error" due to
Sep 22, 2011 | Nortel 7230 Wireless Bridge
Since we update or firware to 0625c6t the wireless headset or not working. can you help thx
You need support from the manufacturer for the wireless headset. I hope this helps. If not please connect with me at: http://www.liveperson.com/nortel-guy/ for service and support.
Aug 11, 2011 | Nortel 1140E
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
Default use name and password with ip address of nortel bap120.
http://192.168.0.1
or
http://192.168.1.1
Mar 16, 2010 | Nortel BAP120 802.11a/b/g Wireless Access...
How do I reset an Ip i2002 phone to factory default
Go into settings and it should be at the bottom "Restore to factory default"
Feb 23, 2010 | Nortel I2002 IP Phone w/Text Keycaps, No...
Nov 04, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
Wireless Bridge
do this to change from routing mode to bridging mode, which allows your MN-500 to act as a wireless access point. Important: If you follow the procedures I've listed below instead of the procedures documented in the MN-500 User Guide, you will not lose the ability to administer the MN-500. This will give you the ability to change the SSID, channel, and encryption key if needed without performing a factory reset of the base station and starting from scratch. 1. While logged into the BSMT, click the Local Area Network link and access the Settings page. 2. Change the IP address from the default (192.168.2.1) to another IP in the same range and set the DHCP server to disabled using the list. Click Apply. In the example shown above, I've changed the IP to 192.168.2.252. Wait for all lights to turn green on the base station. 3. Open the BSMT again using the new IP. Use your Web browser and navigate to http://192.168.2.252 and enter your password if prompted. You will not be able to open the BSMT from the Microsoft Broadband Networking Utility (BNU). 4. Click Security, and then click Network Mode. 5. Click Bridging mode, and then click Apply. 6. Disconnect your computer from the MN-500 but do not disconnect the power from the MN-500 because it may take several minutes for the hardware to restart in access point (bridging) mode.
Feb 19, 2006 | Microsoft Broadband Networking MN-500...
Nortel 7230  Wireless Bridge Logo
85 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Vuk B
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
