Question about Nortel 7230 Wireless Bridge
Compatible product for Nortel 7230 Wireless Bridge
I have one pair of Nortel 7230 Wireless Bridge for connecting two place. One Wireless Bridge has been burnt out today. I have another RADWIN Winlink 1000. My question is the RADWIN Winlink 1000 will be compatible with Nortel 7230 Wireless Bridge ? Both the product look like same but they are different HW & SW version. Both of the product management software is almost same. I will greatful if some one help me in this Wireless Product
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: how do I resolve "authentication error" due to
Go here ->Manual or contact them.Also i read that Nortel is discontinuing availability of the Wireless Bridge 7230 product line. This action is due to a lack in market demand and business justification to continue investment in the portfolio.
Posted on Sep 23, 2011
How do I resolve "authentication error" due to
Sep 22, 2011 | Nortel 7230 Wireless Bridge
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
May 31, 2011 | Belkin F5D4074 Network Adapter
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
Do I need to change the password on this product if the password for my wireless network is changed?
I am assuming you are using it as a wireless bridge to connect wired devices to your wireless network. If that is the case, then yes. You must change your key on all wireless devices (including your bridge) if you change the key to connect to the access point.
Oct 29, 2010 | EnGenius ECB-3220
I have a DG384g as my main internet \ wireless
The D-Link DI-524 only operates in gateway mode, and won't connect to another router. To do what you are looking for, you need a product that offers bridge mode.
Apr 30, 2009 | NetGear DG834G Router
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
Using the DI-624 as a bridge
I don't think it can. An inexpensive wireless access point will work as a bridge. I use the TP Link brand with detachable antenna.
http://www.tplink.com/products/product_des.asp?id=116
Using the terms using the dlink router as bridge you get results of people who claim it can't be done because of firmware. The same question on the D-Link help site mentions DL to DL bridges, but not with the 624.
Carl
Jan 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How to connect Nortel BSR222 (Business Secure Router 222) with tplink
rj11 are connectors used to deliver signals to a device. Mostly, modems will be able to support this type of connection. Make use of a modem, bridge it and connect the router to it.
Aug 17, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
NetComm NP285 xbox compatibility?
when I go to network settings-->advanced--> wireless, it tells me that the wireless adapter was not detected.
Where are you getting this message from?
Dec 05, 2007 | Microsoft Xbox Console
Nortel 7230  Wireless Bridge Logo
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
