Question about Coleman Powermate Powermate 5000W Generator
Brand new Porter cable 5500w 10 hp generator - no output
Engine starts and runs normally. No power to any device that is plugged in. Breaker does not seem to be tripped
  • 169 Answers
I wrote an answer that was for powermate generators, but it should help you too. I think you have a brushless generator, and rather than the plastic endbell I mention in the post you have a metal pie plate held on by 2 phillips head screws (yours is easier to get to)
Rate me if this helps, ask directly if it isn't enough,
Carl
Posted on Dec 15, 2008
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
Why porter cable h450is generator won't start
If it starts initially, then it has spark. most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 07, 2014 | Porter Cable 4,500 Watt 9 Hp Portable...
My EU 2000I ran my half ton AC unit for over a year. It now all of a sudden starts popping the 20 amp breaker anytime I turn it on. It only pulls 10 amps at startup. What's with this? Is it time to...
Make sure it isn't trying to start the HVAC with a locked compressor (IE it just turned off and is now trying to cycle on again) If it is shutting down due to low freq there is too much load for the HP the engine can deliver. That will cause too much current to flow and trip the breaker. Also be aware it takes 6 times current to start HVAC than to run it. How old is the generator? it may have normal engine wear and can no longer generate HP, Also when was it tunes up
Sep 30, 2013 | Honda EU2000i/Companion Parallel Cable/RV...
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
I have a Powermate 5500W, Model PM0645500. The gas engine runs fine, but there is no power output. What can I do?
Sometimes you have to restore the magnetic field in the generator.
Look at the end of the generator....do you see a small + and - ?
You may have to take a cover off.
Take a small 9 volt battery and connect it to theses connections just for a moment.
With everything back together start her up and plug something in to the A/C output.
There is a 75% chance it will work fine now.
Sep 17, 2009 | Coleman Electrical Supplies
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
No power output
Hi, check your exciter cap inside the control box as it probably is knackered, Replace it with a new one.
Or if the unit was severly overloaded the windings are probably fried.
Oct 21, 2008 | Briggs Stratton H7159 & Stratton® 5500,...
Coleman Powermate Powermate 5000W Generator Logo
362 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
