Question about Bose Lifestyle 48 System
Bose Lifestyle V20 Error 180
My Bose Lifestyle V20 won't display anything on the TV and the unit says "Error 180 Call Bose"
  • 7 more comments
  • bfcuk Dec 14, 2008
    Had same problem on my v20.
    total power down cleared fault.
    I suspect I had speaker cable short circuit, but only guessing.
  • bwalls Dec 15, 2008
    i was able to clear it with the power down earlier today. Had the problem re-appear about 2 hours later. I'd had the unit for less than 2 weeks, so we exchanged it at BestBuy this afternoon. We'll see if this pops up again.
  • tayfunbalkan Dec 26, 2008
    yeah mate ..i ve got same problem on my v30 system.but ihave no bloody idea,u guys please help me ..by the way i bought this system from australia but i am using it in turkey.i guest that problem from ******* my power and i am using surge protecter(monster realy good one )as well the turkey supplying 220v..the other issue bose does not supply international warranty..u guys i really stuck
  • Anonymous Jan 17, 2009
    I just purchased the lifestyle V20 and have the same problem. I hope that isn't something that is too serious.
  • Anonymous Jan 21, 2009
    I feel for you it just happened to me; ridiculous
  • cantalinik Jan 25, 2009
    I did the power down thing, fixed it. it reappeared later, whatever... the next day it doesnt work at all, whenever i turn my system on, i get pcm 2.0. for about 15 seconds and then error 180 call bose
    also just wondering with all you guys, i have software verson 01.01.01 getting a software update to try to fix the problem, wondering if you all have the same version
  • aqasim Feb 05, 2009
    i just bought a bose lifestyle v-20 and am getting the same error180 call bose message tried to shut down power but of no use it reappears after a few mins
  • nealsworld9 Mar 27, 2009
    Hello sir
    my name is swapnil gadekar and i am from Goa India .recently i brother is returne from USA and he had bought a bose v20 i installed it properly but it is showing ERROR 180 why is it so please let me know my email ID is nealsworld9@gmail.com
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
First - if you get a 'Error 180 Call Bose' issue come up on the display, and your picture is not showing up on the TV, make sure that the power supply box is switched to '120V' - mine was set to '230V' when I received it, and this took a couple of calls to finally identify as the problem. It causes the video processor to work at the wrong cycle speed. If this still does not fix the problem then you probably have an issue with the HDMI handshake to the Bose system. The software update (next step) might fix it, but in the meantime you can switch to Component cables for the cable to Bose connection. Second - when the system is turned off, press and hold the center button on the display. When 'House Code' comes up, start pressing the ON/OFF button until the 'CONSOLE SOFTWARE' screen comes up - if it shows 2.02.02, then you need to call Bose and have them ship you a software update. NOTE: the software update must be run from a DVD player that has digital optical connections to the Bose system (HDMI works as well).
Posted on Dec 02, 2009
    Problem Solver:
Called Bose and talked to representative. He was extremely helpful. All in all the unplugging of the unit was a quick fix, but he is sending me new software updates. That is the major culprit so I think to permanently fix this issue you need to get the software update! I ended up needing an update for the "handshake" issue and also an update for the software in general.
Posted on Feb 08, 2010
  • 2 more comments
  • Brendan Feb 25, 2011
    Follow up: After the software upgrades the issue didn't not occur again for quite some time. It then cropped up again and I would continuously unplug the unit and plug it back in. Well I got sick of this and decided to call Bose again. Long story short I ended up having to ship the unit to them. They sure were nice and even paid for the shipping!! The frustrating part is that I was never told what the issue was. You get the unit back with a general list of "diagnostic" checks. Customer service is terrible, and to me it seems as if this product IS NOT WORTH THE MONEY!!
    For the money I paid for this "top of the line" system, I think it's ridiculous all the problems I have experienced. There isn't anythign special about it other than the "Bose" name. If i could do it all over again, I would have bought a system with the same capabilities for more than HALF the price!!
  • NutAddy Mar 13, 2011
    NutAddy: Guys, reset all connections and plug all of them back in after a couple mins. It works like a charm!!
    Its not a rocket-science so take it easy!
  • Brendan Mar 13, 2011
    @NutAddy: I did that the first few times it happened. But my question to you is: How many times?? How many times should I reset all the connections before feeling as if there is something wrong here? Before having the feeling, and rightfully so, that this shouldn't be happening for such an expensive part of an entertainment system?
    If your into paying over $1,000 for something that requires you to perform such actions than kudos to you, money is no object.
    To me, it's not rocket science to see that what you get with this is the Bose name an thats pretty much it. People need to know that they can get something else that does just as good of a job for 1/2 the price!!
  • BoseUserV20 Mar 12, 2013
    Very simple solution and working without any issue
I had this "Error 180 Call Bose" and I switched to 120V and it fixed my problem and Bose works properly!
Posted on Dec 26, 2009
Just simply turn power strip off that was used to power on the Bose control panel. Waited 5 minutes, turned back on and it was ok.
This was the first time it happened since having the system for 8 months.
cgeers
Posted on Jan 24, 2010
NutAddy: Guys, just reset all connections and plug them back in a couple mins and it works like a charm!!
Posted on Mar 13, 2011
2 Suggested Answers
SOURCE: Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
Tip
Bose LifeStyle V20 Manual Download
Download Bose LifeStyle V20 Audio System Manual
Would you like to review the features of the Bose LifeStyle V20 Audio System?
Have you lost your Bose LifeStyle V20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose LifeStyle V20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose LifeStyle V20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - black Theater...
Hi, I have an error 180 message in my bose lyfestyle V20
"Error 180" is either very bad (video board is defective) or just a temporary fluke and meaningless.. Best case-> the "error 180" could be fixed by a simple reset (unplug the DC power cable from the media center for about 30+ seconds). Worst case-> this will have to be sent to Bose for repair. Try re-seating any HDMI or component cables at the back panel as well. If you can see your system menu (by pressing 'system' on the remote) then the video board may be fine. If not, still reset it before determining anything else. Also, if the input device (DVD player) is connected with HDMI, and the output (the V20) is component.. this canl cause the error as well.
Jun 09, 2009 | Bose Lifestyle V20 System - black Theater...
Mar 01, 2009 | Bose Lifestyle V30 Home Theater System -...
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - White Theater...
Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Oct 05, 2008 | Bose Lifestyle V20 System - black Theater...
Bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Sep 26, 2008 | Bose Lifestyle V20 System - black Theater...
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Bose Lifestyle 48 System Logo
15,506 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
