Question about Toshiba Satellite A135-S4527 Notebook
Using the battery or not?
Hi sir.i have a toshiba laptob and i use it with its cable and its battey connected to it.i want to know if i have to disconnect the battery when using the cable or not necessary.thank you for your attention
    President:
  • 2,110 Answers
It is better that charge ur battery upto 80% to maximaize the battery life...
Posted on Dec 14, 2008
I have a fully charged battery but nothing comes on. Jiggle the cables and the panel board will light up, but when you try and crank it it clicks and then everything goes dead.
Hi Donnie, It sems to me that you may have a short in the starting system of your vehicle.I would start with finding your ground lead from the battey and make sure that its makeing a solid connection to the frame as well as the battery.I would also do the same to the positive lead to the starter motor and see if you get anything.
Engine Won Crank or Start
May 27, 2017 | Cars & Trucks
Why does mercury 2001 click after battey replaced
The battery is either DEAD or the cables are not properly installed (loose or >) The 'clicking' is the starter solenoid trying to engage.
Jul 23, 2014 | 2001 Mercury Villager
New DVR67)KU toshiba DVD video recorder/VCr recorder Problem: Cannot get on-screen display to set up new DVD machine. Both DVD and TV are Toshiba
unplug everything lets start over.....the TV is set on Ch 3..........and is working.... the new DVD machine should have red, white and yellow RCA cable.... connect these to the correct DVD outlets ........now connect it to the TV (digital IN)..... this is to view........ now to record using the F connecting cable plug this into the DVD (rear top right hand corner) this should be coming from your sat/cable out ........... now from the DVD F connector out .this goes to the TV...........note to record from another DVD player use the front jacks.........turn the power on and enjoy that movie(s)
Jan 27, 2011 | Toshiba Televison & Video
Can I jump start the CLS500 from the 12-V lighter plug
Don't do that, if you don't know how the jump start Mercedes Benz be careful it's so dangerous, if you do one simple wrong thing when you jump start it can damage your all electronic management system if in case you did the wrong thing you may have to spend $ xxxxxxx, if you don't know how to do that get help from someone who know how to do it, keep in mind don't mix up negative and positive cable when you jump the battey at least jest for a 000.1 second, that's enough for get damage, battery jump start point in engine compartment have a good look, has covered by read cap, open cap and you can see copper point in it fix the read battery cable (+ positive cable) on it then connect other end of same cable to the + terminal of battery again I would like to remind don't mix up, after connect + terminal please double check did the right, then connect - cable on to the Body ground connection near by positive point you can see another probe for ground it's located near the shockabsober top mount, after that connect other end of negative cable to the negative terminal of battery before connect it once again check other 3 connection are in right order
+ battery......................................................... + car
- battery.......................................................... - car
__________________________________________________________
you can also jump the battery to battery
+ battery jumper................................+ battery in the car
- battery jumper................................- battery in the car,
is this information helped you?
Oct 26, 2010 | 2006 Mercedes-Benz Mercedes Benz CLS500
Hi i have a 91 dakota i have a new batery alternater the battey is not get chaged when it runs verything looks good i do not know ware to start looking
you say you replaced the alternator and battery but what is the voltage output at the alternator and how much voltage is getting to your battery?
may be a voltage drop on the large battery cable from the alternator to the battery
Apr 04, 2010 | 1991 Dodge Dakota
Battery Charger
use your usb cable plug it into your computer and keep the unit off and it should charge the unit.
Sep 02, 2008 | Beyond ePod Digital Camera
A question
Does your monitor on the laptop have a power switch, seperate from the system power switch? this might be the case, and if so you will need to turn it on :) it might also be a wiring problem, where the battery wires have become disconnected from the screen. Hope this helps :)
May 25, 2008 | Toshiba Satellite A135-S4527 Notebook
NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Feb 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
