Question about Maxi-Cosi Priori
Lost one of the yellow connectors for isofix for Maxi-Cosi Priori
We have lost one of the yellow connectors for the isofix when we moved ther seat from one car to another.
I have googled spare parts but cannot find any.
Does anyone know where I can buy another connector?
The 'Isofix guides' are available to buy from Dorel UK LTD (01842 767965) (See maxicosi website/customer services) for £7.99+P&P @ £3.99.
When I called (as one of mine is broken) they told me they are not essential to fit the car seat safely - they are simply 'guides' and if the actual forks on the seat are not damaged in anyway; not having the guides will not affect the car seat performance in any way.
Kindest regards
Glitterbabe628
Posted on Jul 29, 2009
Chicco Oasys 1 isofix connectors jammed
Please contact Chicco for assistance
Chicco UK Home
Oct 16, 2014 | Baby Gear
Lost Maxi cosi recyning rod
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Apr 01, 2014 | Maxi-Cosi Priori
Please help. I have been handed down a britax ASIs car seat which has isofix. Problem is my car does not have isofix. Can I still use it? And do I need to take isofix off? Thanks
Usually the ISOFIX is simply an easier way to tether the seat to the car. Some believe it is safer than tradional tether methods.
You can simply use you car's seatbelts to hold the car seat in. The car seat has 2 large holes behind the childs lower back and that is where your car seat belts slide thru and then click into their connections.
Here is a link to Britax info on the Isofix and Isofit
Britax Info
Apr 25, 2012 | Britax Baby Gear
Hi, I just installed the isofix base Maxi cosy isofix without the yellow adapter. Know I am worried this could be a problem without using the, Does all users have these on? Is it necessary?
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
Sep 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can the isofix easyfix base be used safely without the isofix guides, ours are missing, thanks.
Good Afternoon
The yellow plastic IsoFix guides are for assistance only when fitting the unit and make no difference to the performance. If you are able to fit the base so the indicators go green it is fine to continue using without the guides. Alternatively if you need replacement guides they can be ordered via your retailer or direct from our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Sep 10, 2011 | Maxi-Cosi Priori
I have the isofix easy fix base. It will not come out of the car. We press in button in and pull and it does not move at all. It's almost like the locking mechanism has jammed. Any suggestions?
Good Afternoon
On either side of the EasyFix base you will see a small square opening with the yellow IsoFix point showing through it. Take a flat head screwdriver and slide into this hole facing toward the front of the car and gently push the screwdriver handle so it ends up facing the rear of the car - this should unlock the IsoFix mechanism. You'll need to do it on both sides if both sides are stuck.
If this doesn't work, or once you have done this, take the base back to your retailer with your proof of purchase if it is under 2 years old and they will be able to assist.
Aug 14, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi-cosi priori, and i need to adhust the top strap? and i lost the instruction manual??? please help
The maxi-cosi priori manual can be found here: http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/4358-4274%20US%20Priori.pdf
Aug 09, 2011 | Maxi-Cosi Priori
I have lost the yellow plastic parts that make the isofix seat work. where can i get replacements?
Good Evening
The yellow plastic IsoFix guides can be ordered via your local retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The RRP is £10 (set of 2) with £3.99 p+p if you order direct.
Bear in mind that these are guides only and may not be required. Some cars have the IsoFix points very prominant and quite high up so you can slot the IsoFix connections on without the guides; They are only to help if needed, if the IsoFix points are located quite deeply within the cushion of the vehicle seat.
May 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do you move shoulder straps up??
Hi Linda - Instructions are in your user manual. If you have lost your user manual a replacement can be downloaded at www.maxi-cosi.com
Apr 10, 2011 | Maxi-Cosi Priori XP Booster Car Seat -...
Maxi-Cosi Priori Logo
1,624 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
