Question about Chief Manufacturing OPEN BOX Chief MFCUB Flat Panel LCD Mobile Cart - Black Plasma TV
Which is more energy efficient plazma or LCD?
Just wondering and I've looked for the answer to this question before.
  • 585 Answers
Plasma's tend to be a little more vivid. the LCD's tend to be more trouble-free. For these differences, the LCD will consume about 2/3 the power of the Plasma. Check the product specifications when shopping. They must indicate maximum power consumption in watts. Hope this helps!
Posted on Dec 14, 2008
Tip
Make Your Pool Green!
Energy Efficiency <i>Make Your Pool Green!</i><br /> Pool owners LOVE green pools. Crazy statement if the "green" you're thinking about is unclean, algae-filled water. But when "green" means eco-friendly, a "green" pool is something homeowners should aspire to have in their yards.<br /> Energy Efficiency - Why? Why should I build or upgrade to an energy efficient pool?<br /> <ul> <li><b>1) Reduce Costs:</b> You'll save money. Energy-efficient pool appliances always pay for themselves in reduced electric bills, and then continue to save money for years to come. By choosing pool equipment such a variable speed pump or pool cover, and by establishing good habits like lowering the pool heater when not in use and proper preventative maintenance, costs to a pool owner can be greatly decreased.</li><br /> <li><b>2) Cuts down on energy waste and saves water:</b> Almost all of a pool's heat loss-about 95 percent-occurs at the surface, mostly through evaporation to the air and radiation to the sky. By using a pool cover to prevent heat and water loss, the amount of chemical water treatment will also be reduced. A multispeed or energy efficient pool pump can also significantly reduce the power consumption of a swimming pool by over 65%.</li><br /> <li><b>3) Tax incentives and rebates:</b> Did you know that some states offer tax incentives and rebates for homeowners that purchase energy efficient pool appliances? Check to see what incentives or rebates are available in your state..</li><br /></ul> Energy Efficiency - How? With a combination of pool products and good preventative maintenance habits, you can improve the heating and energy efficiency of your swimming pool.<br /> <ul> <li><i>Pump Efficiency-</i> You can save energy and maintain a comfortable swimming pool temperature by using a smaller, higher efficiency pump and by operating it less. On average, an energy efficient pump will use 30-45% less energy than that of a standard pump. The difference over a season can be immense. Pumps now come in two-speed, four-speed, and variable-speed models, so you can turn the speed down for regular daily use saving a lot of energy, and use higher settings for more thorough, less frequent cleanings. New energy-efficient pumps also move the water more efficiently for further savings. Since pumps circulate the water to keep it clean, the better they work, the less a filter has to work. <ul> <li>The <a href="http://www.pentairpool.com/pool-pro/products/pumps-inground-intelliflo-vs-3050-vs-svrs-variable-speed-pumps-76.htm">Pentair IntelliFlo&reg;</a> High Performance Pump is the world's smartest swimming pool pump. Its onboard computer and intelligent software automatically calculate and program the minimum flow requirements for every pool task - filtering, heating, cleaning, spa jets, water features and more - to optimize performance and minimize energy use. As functions/tasks change, IntelliFlo&reg; self-adjusts to maintain optimal flow rates for further energy savings.</li><br /> <li>With the <a href="http://www.haywardcanada.com/inground/products/pumps/EcoStar.cfm">Hayward EcoStar</a> family of pumps, money flows back into your pocket. EcoStar is the industry's most energy efficient variable speed pump, thanks to a super-efficient permanent magnet, totally enclosed fan cooled (TEFC) motor and industry leading hydraulic design. Tests prove that EcoStar can save you up to 90% on energy costs compared to ordinary single speed pumps. EcoStar matches pump flow to a pool's needs, versus running at full power 100% of the time. It's fully programmable with a self-contained 24-hour clock and up to 8 custom speed and timer functions that allow EcoStar to manage flow throughout the day. Whether used in new construction or aftermarket applications, EcoStar is the perfect choice.</li><br /> <li>Pentair has a calculator that you can use to <a href="http://www.pentairpool.com/pool-owner/resources/calculators/pool-pump-calc/index.html">calculate your energy savings</a> using an energy efficient pool pump.</li><br /></ul></li> <li><i>Pool Covers-</i> A good pool cover will save energy and water. It can keep the water in your pool an average of 10 degrees warmer, which can cut summertime pool heating costs by up to 90 percent. A cover reduces water and chemical evaporation by up to 70 percent, saving nearly a thousand gallons of water per month. A cover also helps keep your pool clean, which means you'll have to run your filter pump less often, saving even more energy.</li><br /> <li><i>Water temperature efficiency-</i> In addition to a pool cover, there are other ways to help keep the cost of heating your pool to a minimum while you still enjoy a comfortable water temperature. Make use of solar energy by locating your pool in the sunniest part of your yard. If possible, screen it from the cooling, prevailing wind with existing structures such as the house or garage, or add a solidly built fence as a windbreak. The water temperature you desire for your swimming pool not only affects the size of the pool's heater, but also your heating costs if use a gas or heat pump pool heater. Heating your pool with solar energy is by far the most energy-efficient method. If you buy a gas or electric heater, check the yellow-and-black Energy Guide label on the appliance. It shows relative energy-efficiency according to tests by the US Federal Trade Commission (FTC). Pool water temperatures typically range from 78&ordm;F to 82&ordm;F. The energy consumption for each degree rise in temperature will cost 10%-30% more in energy costs, depending on your location. In warmer climates, this percentage is higher because of the relatively low cost of heating a pool at 78&ordm;F.</li><br /> <li><i>Timers-</i> Buy automatic timers for both your pool heater and pump. This will allow you to run them in several short cycles during the day, which is more effective than running them once continuously for several hours a day.</li><br /> <li><i>Preventative Maintenance-</i> Maintain efficient daily operations. Turn down the pool heater when the pool is not in use and maintain appropriate water temperatures when in use (78&deg;-80&deg; for active swimming, 82&deg;-84&deg; for recreational use). Raising the water temperature just 1&deg;F can costs an additional 10 - 30%, depending on your location. Keep a thermometer in the pool to help determine the temperature that is best for your pool and mark the "comfort settings" on the thermostat dial to avoid accidental overheating. Backwash the pool filter only as much as necessary to avoid wasting water and energy and be sure to keep drain systems clear to allow the free flow of water. By far, the most energy efficient lights you can get for the pool are LED or solar powered.</li><br /></ul> Energy Efficiency - Not just for pools! It is also possible to make your spa energy efficient. Portable spas are more energy efficient than in-the-ground spas because they are better insulated and usually have covers. If you have a typical portable spa, your heater will heat water 10 degrees in about 8 hours. If you use your spa once a week, lowering the temperature 3 degrees when not in use will save you approximately 5-10% of your spa heating costs; if you use the spa less often, your savings could be even greater. Don't run the jets unless you are using your spa. The mixture of water and air is great for relaxing the muscles, but it cools the water quickly. Spa covers are important. Be sure to leave the cover on until you are ready to use your spa and replace when you're finished. Remember that the heat that escapes is the heat you must pay to replace.
on Mar 17, 2011 | Pool & Spa
Tip
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers. Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models. Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system. Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period. SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings. The higher efficiency your product, the lower your long-term energy costs will be. Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place. Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost. Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations. If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
on Dec 14, 2009 | Heating & Cooling
Is the Amana brand energy efficient?
Some do but I cannot answer without the model number. Why not just ask the sales cleark.
Aug 10, 2014 | Amana Dryers
What does energy efficient mean?
It means that it accomplishes the same task as similar equipment, but consumes relatively less energy accomplishing that task than previous (or other current) examples of similar equipment. "Energy efficient" is not an absolute term - there can't be any single unique piece of equipment with no peers that can call itself "energy efficient"; it's strictly a comparitive term. That which we today call "energy efficient" will tomorrow be thought of as horribly wasteful and inefficient.
Was offered a new energy efficient freezer 16.7 cu foot standing frost free by Fridgidaire ( energy efficiency rating 65). My 13 yr old Kenmore: Model : 253.9287215 Freezer works fine. Is it rated the...
I was not able to find any info quickly on your older Kenmore in my literature but its a sure bet that it was not as efficient as the new one. You can do a calculation or look at the plate (usually on the back) that states the amperage draw on each model- the higher one is the less efficient. As for cuft you need to do the math and measure the inside storage area in inches wide, inches deep and inches tall. Multiply the width X depth X height then divide by 144 (the cu inches in a cubic ft) this will give you the actual size of the Kenmore for comparison. Hope this helps... also you may want to check with your local electric utility company as many are offering a rebate to replace 10 yr old fridge. freezers and usually pick up for free.
May 15, 2014 | Freezers
Dawjoy@att.netwhat is the difference in LCD and LED
LED = light emitting diode LCD = liquid crystal display
LED is better looking and more energy efficient, LCD is cheaper though
Apr 06, 2011 | Televison & Video
We are an Ace Hardware Store and we sold a water heater to a customer, and the sticker on the outside of the box that had the information for energy was discarded by us and now the customer wants the...
Dort is Reliance.
http://www.reliancewaterheaters.com/prod/elec.html
6-50 Dort is 606 series
Your Customer wants energy factor.
Pdf below shows energy factor for 606 series:
http://www.reliancewaterheaters.com/lit/spec/electric/R606E0510.pdf
55 gallon has .90 energy factor.
4500 watt water heater costs about $48 per month with electric prices at 12 cents per Kwh
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Read about energy factor:
http://www.energysavers.gov/your_home/water_heating/index.cfm/mytopic=13000
"...energy efficiency based on the amount of hot water produced per unit of fuel consumed over a typical day. This includes the following:
  • Recovery efficiency - how efficiently the heat from the energy source is transferred to the water
  • Standby losses - the percentage of heat loss per hour from the stored water compared to the heat content of the water (water heaters with storage tanks)
  • Cycling losses - the loss of heat as the water circulates through a water heater tank, and/or inlet and outlet pipes." end quote
Energy factors exist so large appliances can be compared to small appliances.
-This is like comparing aircraft-carriers to small ships.
-The purpose is so large gigantic appliances look like reasonable energy alternatives, when that is not actually true.
-The aircraft carrier could have better efficiency number than smaller ship, and it gives misleading appearance that aircraft-carrier will save the consumer money. Many of the super high-consumption 80 gallon water heaters have higher energy factor, but they consume huge amounts of energy each time operated. Simple Dort series is a better value even with lower efficiency number.
-The efficiency number is only for a new product. There is no measure showing how long that product will maintain the efficiency rating.
-And lastly, the manufacturer is putting energy factor on the product, like writing your own performance review, so who can possibly double-check the energy factor.
Dec 29, 2010 | Reliance Water Heaters
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Chief Manufacturing OPEN BOX Chief MFCUB Flat Panel LCD  Mobile Cart - Black Plasma TV Logo
351 people viewed this question
Top Chief Manufacturing Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Chief Manufacturing Furniture Expert? Answer questions, earn points and help others
