Question about Philips 60P8341 60" Rear Projection Television
Brightness Problem Ever since we recently received cable television through our local phone company, I have noticed that our television picture is brighter than normal, almost kind of glowing around sharp colors. I have adjusted the brightness level and color levels, but nothing I do seems to help. I have used our DVD player, and it does the same thing, so it makes me think it is a tv problem instead of a cable problem. Any suggesions of what might be going on?
  • 4 more comments
  • Rachel Niedert Mar 16, 2007
    Thank you for the solution, however, I am still a little confused. The complete picture has an overall brightness/glow to it. Colors seem to glow past their outlines and whites are pretty bright (is this called ghosting??). We have tried to adust the converge red and blue, but the crosses in those screes glow so much that I cannot align them even if I wanted to.
    Does the solution still hold with this additional information? Thank you!
  • Rachel Niedert Mar 20, 2007
    Actually, no one is allowed to smoke in our house, so I can rule that issue out. But, when they installed the new cable, the technician drilled into the wall to add two new phone jacks -- right behind the t.v. That may have caused the lens or tubes to have gotten dusty or dirty. Thank you for your help!
  • Anonymous Oct 19, 2008
    So how do you clean the bulbs?
  • Jeff Lacy
    Jeff Lacy Oct 19, 2008
    How do you get to the tubes?
    What do you clean them with?
  • Jeff Lacy
    I have the the same glowing brightness issue.
  • tkebro576 Dec 01, 2008
    i have a brightness issue. it appears a that the color around in image tends to bleed over
    President:
  • 3,130 Answers
If it is a glow around the edges, it could be one of two problems. The Picture tubes could be getting soft or weak, or there is a bad capacitor in the screen drive circuit or in the sweep power supply. If you have a service manual and a multimeter, you should be able to locate a bad capacitor with an ESR type capacitor checker. If you do not have any knowledge on solid state repairs, please call in a pro to assist you in this repair. Good Luck.
Posted on Mar 16, 2007
  • Larry  Dillon
    Larry Dillon Mar 17, 2007
    Have you looked into the tubes to see if they are dirty or if the lens have dirt or dust on them? Also try to adjust each focus by rocking back and forth the focus control for the color that your looking into and see if the focus improves the look of the set. If you smoke or anybody smokes in your house this would explain alot.
I keep receiving a sign about black out restrictions so it won't aloud me to see some shows
You cannot open a MacDonald's across the street from another one, because they have a franchise and a protected area. Television Networks operate almost the same way. If you own a TV station that carries THE TV network in your town and a local cable or satellite company has THE TV network available from NY and TX, you have the right as the local THE TV network affiliate to request that cable or satellite company not DUPLICATE your programming. That company must abide by FCC rules and display the blackout notice. The next time that you see the sign about blackout restrictions, check to see if it tells you that the program is available on your local channel.
Oct 06, 2018 | Cell Phones
My Panasonic 47 inch rear view projector is hdtv ready, what do I need to buy to recieve pictures in HD
You should be able to receive the HD signal from your cable company. If you are still receiving your signal over the air, then you can buy an HD tuner. I found mine at Best Buy for $179 a few years ago. It will come with component outputs which is the HD signal.
I'm using my 70's vintage antenna on my house to receive the 3 local channels in HD.
Good Luck,
Jan 19, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hdtv qam tuner
More often than not the problem is with the Cable co. They ALWAYS blame the tv. I have had many many problems with the signal quality coming from that co. Here is the most likley cause. The cable signal is probably very Weak. This can be caused by a weak signal coming from the cabls co. or a bad cable inside your home. The age of the cable can effect the signal quality.Note: The cable co is only required to provide a Digital signal. Some companies allow free HD signals and some charge for that signal. The correct approach to this issue is to get with the Cox and ask the if they provide free Hd channels without a box. If they say no then you will have to get a HD cable box to watch HD programs. Themn if they say yes then you need to ask them to send out a tech and test the signal coming from the Head End all the way to your set. If the signal flucuates then you will get inconsistant scanning results.
Jul 04, 2009 | Samsung LN-T4665F 46 in. LCD Television
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Sanyo LCD
Try to re-program your tuner (search for channels). There are a lot of changes going on with service providers.
I am a servicer, and I have had to reprogram many sets because the local cable company just recently switched there services from analog (NTSC) to digital (ATSC).
Your problem might possibly be an internal problem, but most likely related to the aforementioned.
Having said that, there's always a possibility that a problem exists with your service providerw
If the above, reprogramming channels, doesn't work, then call your local cable or sattelite service provider. If that doesn't work, next person to call is your repair tech. Especially if it is under warranty.
Tim
Certified TV
Jan 09, 2009 | Sanyo DP32746 32 in. LCD Television
Picture problem
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
Dim picture
I would check the 160 volt radial lead capaitors in the high voltage circuit for high ESR or change in capacitence.
Dec 27, 2007 | Panasonic PT-51HX40 51" Rear Projection...
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Samir
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Philips 60P8341 60" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
